Fog lights/high beam
Old Feb 19, 2003 | 09:55 AM
LinearX's Avatar
Is there a handy dandy little relay that we can jump like in the 2nd gen trucks to make the fog lights stay on with the high beams? I've looked in the service manual, and I recall seeing something about a relay in the engine compartment, but I looked in the fuse/relay box and didn't see one listed.<br><br>Anyone got any ideas?
Old Feb 19, 2003 | 12:44 PM
rydblue's Avatar
Re:Fog lights/high beam
I would like to know how to do this as well. I found the relay but the pins are all different from the 2001 that I had. Just need to figure out which pins to jumper. Anyone crack the code yet?
Old Feb 19, 2003 | 03:17 PM
LinearX's Avatar
Which relay is it in the power distribution center in the engine compartment? If I can find it, I'll just start jumpering until they work, or I cook something.
Old Feb 19, 2003 | 04:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Cool Avatar/smiley.
Old Feb 19, 2003 | 10:02 PM
LinearX's Avatar
[quote author=Shovelhead link=board=17;threadid=11148;start=0#106617 date=1045694066]<br>Cool Avatar/smiley. <br>[/quote]<br><br>Heh...thanks. I stole it off of another board that I'm on. It's one of the smileys in available for posting, but I thought it'd be a good avatar.
Old Feb 19, 2003 | 10:18 PM
P Kennedy's Avatar
Okay guys why would you want a Fog light on with high beams- this causes a hot spot in front of the truck and impairs the ability to see distance with the high beams. PK
Old Feb 20, 2003 | 08:05 AM
rydblue's Avatar
LinearX - it is in the underhood relay center, it is labeled fog lamp or fog, you have to look through the diagram. I don't have the truck nearby today so I cant tell you offhand which exact one it is. You have alot more courage than I do to start jumping terminals, but I'm behind you 100%!! Let me know what you find. It made a ton of difference on my 2001, having the fogs on with the brights.
Old Feb 20, 2003 | 12:20 PM
LinearX's Avatar
[quote author=P Kennedy link=board=17;threadid=11148;start=0#106759 date=1045714691]<br> Okay guys why would you want a Fog light on with high beams- this causes a hot spot in front of the truck and impairs the ability to see distance with the high beams. PK<br>[/quote]<br><br>One of the things that happens when you turn the high beams on is that all of your short range light. The high beams are fine, but I like being able to see the area in front of the truck as well.<br><br>
Old Feb 20, 2003 | 12:41 PM
Commatoze's Avatar
How aboout burning both high and low beams at once? That I help you with.
Old Feb 20, 2003 | 08:24 PM
LinearX's Avatar
[quote author=Commatoze link=board=17;threadid=11148;start=0#106988 date=1045766482]<br>How aboout burning both high and low beams at once? That I help you with.<br>[/quote]<br><br>Do tell....
Old Feb 20, 2003 | 08:27 PM
Commatoze's Avatar
It's called The Brite Box. You can get it Geno's Garage. It's a relay and harness that allows both beams to burn at once without smokin' the switch.<br><br>Tom
Old Feb 21, 2003 | 12:53 AM
cfm3110's Avatar
um...just a suggestion, but you may want to check into your state laws, because i know that is illegal in KY to run high beams and fog lights, one of my friends just recently got a ticket for it. you may be fine where you are from, and if not you probably wont get caught
Old Feb 21, 2003 | 09:11 AM
Mopar_Mudder's Avatar
[quote author=cfm3110 link=board=17;threadid=11148;start=0#107252 date=1045810399]<br>um...just a suggestion, but you may want to check into your state laws, because i know that is illegal in KY to run high beams and fog lights, one of my friends just recently got a ticket for it. you may be fine where you are from, and if not you probably wont get caught <br>[/quote]<br><br>Same here in WI, that is a no no &gt;
Old Feb 21, 2003 | 09:26 AM
LinearX's Avatar
[quote author=cfm3110 link=board=17;threadid=11148;start=0#107252 date=1045810399]<br>um...just a suggestion, but you may want to check into your state laws, because i know that is illegal in KY to run high beams and fog lights, one of my friends just recently got a ticket for it. you may be fine where you are from, and if not you probably wont get caught <br>[/quote]<br><br>I've got friends that have been doing it for years with their 2nd gens. I don't see why it's illegal if I'm not bright lighting anyone. Wouldn't the cop have to be in front of me to see it?
Old Feb 21, 2003 | 09:39 AM
[quote author=LinearX link=board=17;threadid=11148;start=0#107326 date=1045841189]<br>[quote author=cfm3110 link=board=17;threadid=11148;start=0#107252 date=1045810399]<br>um...just a suggestion, but you may want to check into your state laws, because i know that is illegal in KY to run high beams and fog lights, one of my friends just recently got a ticket for it. you may be fine where you are from, and if not you probably wont get caught <br>[/quote]<br><br>I've got friends that have been doing it for years with their 2nd gens. I don't see why it's illegal if I'm not bright lighting anyone. Wouldn't the cop have to be in front of me to see it? <br>[/quote]<br><br>It doesn't matter why it is ellegal, it is. No one knows where many of these laws came from.
