Foam!
Old Aug 8, 2005 | 07:17 AM
Lee S's Avatar
Foam!
I aked recently if others had inaccurate fuel gauges. I thought mine was off. Well, yesterday, I discovered it is worse than I thought.
The foaming never bothered me when filling up because I just assumed it was a minor thing. I would pump till it shut off, then round out to the next dollar. Yesterday I thought I would pump till I could see diesel in the filler neck so I could get an accurate mpg figure. I was showing that I had just over 3/4 tank of fuel at the time.
The pump kicked off a little over 10 gallons. I pumped on to about 11 gallons which is where I would normally stop. Then I pumped some more. Stop. Pump. Stop. Pump. The guy in the Texaco said he thought I must be pumping in over 100 gallons since I was there so long. I ended up putting 16.38 gallons in the truck before liquid fuel was visible in the filler neck!
I did not realize how much the foaming was affecting my fill ups--around 5 gallons extra. I had never had a full tank of fuel until yesterday.
Old Aug 8, 2005 | 07:21 AM
Geico266's Avatar
If you put your finger over the anti spill hole in the nozzle I have been told this helps stops fuel foaming. Also, this is another good reason for keeping your fuel tank at least 1/2 full. Those little bubbles and cause heck with your LP, IP, and injectors.
Old Aug 8, 2005 | 07:44 AM
JohnnyH's Avatar
Lee....One thing you may consider is a Fuel tank vent modification that a TDR and DTR member put together. It greatly reduces the time it takes you to do what you did. It replaces the stock vent with a new one higher in the tank. Works very well. Let me know if you are interested and I will try and get you a link.
John
Old Aug 8, 2005 | 08:24 AM
WA4SLC's Avatar
I put the Fuel tank vent modification on my 04.5 and it works great. It would take me about 15 to 20 min. to fill up completly before, now it only takes about 5 min. It is probaly the best $35 that I spent on my truck.
Bill
Old Aug 8, 2005 | 09:17 AM
The Domie's Avatar
put the fuel tank mod on. its the best mod available! I did mine and WOW WHAT A DIFFERENCE.
Do a search for it on this site and you will get the specs.
Old Aug 8, 2005 | 09:18 AM
rock's Avatar
I put the fuel vent on my truck also and WOW what a diference. No more 20 minute fuel stops for me!
Old Aug 8, 2005 | 10:36 AM
WL.'s Avatar
WL.
Get the vent kit from David and you will eliminate all of your fill up problems. Takes about 30-40 minutes and your done. Besides that, hes a great guy to deal with.
Old Aug 8, 2005 | 11:57 AM
4x4not's Avatar
I really need to get off my duff and buy that kit. It is hard enough to find diesel around here, and then to spend 15-20 minutes filling up while some rich-Edit is waiting to fill up her Mercedes is getting old
Old Aug 8, 2005 | 02:45 PM
4X4 HULK's Avatar
Can someone link me to a web site to Dave's vent kit?
Old Aug 8, 2005 | 02:53 PM
MedicShawn's Avatar
Here's the link.
I also installed his kit and would recommend it.
Old Aug 8, 2005 | 03:24 PM
4X4 HULK's Avatar
Thanks.
Old Aug 8, 2005 | 11:58 PM
Dieseljunkie's Avatar
I think I need to do this to my truck as well.. just to do one more thing to it LOL.. Looks like it would eliminate my 15 minute fill ups..
Scott
Old Aug 9, 2005 | 06:07 AM
nonford's Avatar
I tend to believe that the vent mod is in the top 3 to do on our trucks. Fill and go with out waiting to really "Top Off"!
Old Aug 9, 2005 | 03:07 PM
4X4 HULK's Avatar
My money is on the way
Old Aug 11, 2005 | 10:34 AM
2003Ram's Avatar
Mine's got it too. Great Mod. I was never one to stay around to get the tank completely full - no patience for that. Now I can get it to the top without issue.
