Flash
Old Jun 10, 2008 | 08:21 PM
Angus Breeder's Avatar
Flash
I know this is a rookie question, but what happens when you flash your truck? I have seen several places on here where you are discussing flashes and I have no idea. How long does it take, how much does it cost? What does it change?
Old Jun 10, 2008 | 08:47 PM
donhov's Avatar
Try to make it easy. Dealer usually does the flashes. If vehicle is under warranty no charge, if out of warranty depends on the dealer. Flashes usually deal with a problem and create a solution for it. Poor mileage, may change timing. That is an easy one but you should get the idea. The manufacturer discovers a problem, then develops a change in the software to deal with the problem and when you bring in your vehicle for that problem the re-flash might be the way to correct your problem. There are other things they do so it is many different things that a flsh does. On the newer 6.8's then have changed the paramaters for when the DPF re-generates by altering the paramaters in the flash. Hope this makes sense.
Old Jun 10, 2008 | 09:04 PM
steelblitzkrieg's Avatar
DTR Detective
Or even more common on the 6.7.
Old Jul 5, 2008 | 03:49 AM
10-9jc's Avatar
Hmmmmmm - is THAT what it is !!??
I thought "Flash" was what the gals did on their second
floor balcony when we went by Code-3 in big Red!
Live and learn, I guess!
cramel
22
Oct 23, 2008 08:06 PM
Flattman
Oct 16, 2007 01:07 PM
CamperAndy
May 18, 2007 12:36 AM
8mpg
Apr 28, 2006 10:08 AM
04RAM2500
13
Dec 17, 2004 10:02 PM
