Engine Block Heater
Engine Block Heater
I Cannot Find Any Instructions For The Engine Block Heater For The 2006 Dodge Trucks. Can You Just Plug It In When You Get Home And Let It Run All Night When It's Cold Outside? Is It Only Supposed To Run For A Couple Of Hours?
Yeah, I think a lot of us run a timer set to come on 2-4 hours before it's time to go to work (depending on temp) but that's mainly to avoid wasting power...
Mine is parked outside (too big for garage) so I took the precaution of putting in a GFI outlet...
For the first few times in the fall I loop the extension cord over the driver's mirror, so as not to forget to unplug.
I called the dealer and asked. They said it was thermostatically controlled. Don't know about that. The only thermostatically controlled block heaters I've seen are on our diesel generators. They're a lot bigger. I leave mine plugged in all night. Just makes for an easy start in the morning. Hasn't hurt anything. Like the guys above said, put a timer on it and it'll save some electricity.
We're only in the high 30's to low 40's overnight...with the occasional drop to low 30's. I obviously don't need it to start the engine. However, it is nice not having to wait for the grid heater and having some amount of heat in the morning.
I do have it on a timer plugged into a GFI outlet. Timer set for 2hrs and the water temp is usually 100-105. If I let it go for 3hrs, it gets to ~110.
HTH
Tony
HTH
Tony
Hey Rock Crawler,
I'm a little late to the game here but wanted to put in my $0.02 worth. If you haven't purchased anything yet, particularily just a cord, I bought a great set-up for mine from a Dodge dealer in Texas which is in the links column of this site. Paid around $150.00 for it and it came with the block plug and two heated battery blankets all in one easy kit. I have mine set on a timer to come on for 4 hours before I leave in the morning and this thing is at or around 120 toasty degrees when I get in.
I can't imagine leaving it on all the time though. When I first did it, my electric meter on the house was spinning like a CD player and my bill was nothing to laugh about. 2-4 hours works good for our somewhat cold Wisconsin nights.
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
