electrical problems
Old Sep 18, 2012 | 09:55 AM
patg's Avatar
electrical problems
the last few weeks my overhead console has been going on and off,mostly off, the blinkers are messing up, the air bag light comes on and off, sometimes when trying to start the truck, the key acts like it wont go far enough to start, like it isnt all the way in park, the lights will come on and off by there self. the truck runs good no problems there, but the electrical problem seems to be getting worse and worse. any advise would be helpfull, thanks
Old Sep 18, 2012 | 03:05 PM
jhenson's Avatar
Just a shot in the dark, but these trucks are very picky about low voltage from the batteries. How old are yours?
Old Sep 18, 2012 | 08:42 PM
patg's Avatar
i replaced both batteries about 12 months ago, i took out the multifunction switch today and cleaned it real good. the overhead console still doesnt work, but blinkers seem to be ok now. i can pull the #11 fuse out and re install it and the console will work for a few minutes but then quits again, plus the check gauges light is on and it is throwing code p 0341
Old Sep 18, 2012 | 09:19 PM
RamGazer's Avatar
10 Year Member
I hope this will help you out some.
Dodge Ram Computer Fault Codes (ALL)
• P000f Fuel System Over Pressure Relief Valve Activated
• P0016 Crankshaft/Camshaft Timing Misalignment - Bank 1 Sensor 1
• P0031 O2 Sensor 1/1 Heater Circuit Low
• P0037 O2 Sensor 1/2 Heater Circuit Low
• P003a Turbocharger Boost Control Module Position Exceede Learning Limit
• P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance\
• P0049 Turbocharger Turbine Overspeed
• P0069 MAP/BARO Correlation
• P006e Turbocharger Boost Control Module Supply Voltage Circuit Low
• P006f Turbocharger Boost Control Supply Voltage Circuit High
• P0071 Inlet Air Temperature Sensor Rationality
• P0071 Ambient Air Temperature Sensor Performance (TIPM)
• P0072 Inlet Air Temperature Sensor Voltage Too Low
• P0072 Ambient Air Temperature Sensor Circuit Low
• P0073 Inlet Air Temperature Sensor Voltage Too High
• P0073 Ambient Air Temperature Sensor Circuit High (TIPM)
• P007c Charge Air Cooler Temperature Sensor Circuit Low
• P007e Charge Air Cooler Temperature Sensor Circuit High
• P007e Charge Air Cooler Temperature Sensor Circuit Intermittent/erratic
• P0087 Fuel Rail Pressure Too Low
• P0088 Fuel Rail Pressure Signal Is Above Max Limit
• P00af Turbocharger Boost Control Module Performance
• P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
• P0097 Intake Air Temperature Sensor 2 Circuit Low Input
• P0098 Intake Air Temperature Sensor 2 Circuit High Input
• P0101 Mass or Volume Air Flow Circuit Range/Performance
• P0102-mass Air Flow Sensor "a" Circuit Low
• P0103 Mass or Volume Air Flow Circuit High Input
• P0106 Air Pressure Sensor Rationality
• P0107 Manifold Absolute Pressure/BARO Sensor Low Input
• P0108 Manifold Absolute Pressure/BARO Sensor High Input
• P0111 Intake Air Temperature (IAT) Sensor Rationality
• P0112 Intake Air Temperature (IAT) Circuit Low Input
• P0113 Intake Air Temperature (IAT) Circuit High Input
• P0116 Engine Coolant Temperature (ECT) Sensor Rationality
• P0117 Engine Coolant Temperature (ECT) Circuit Low Input
• P0118 Engine Coolant Temperature (ECT) High Input
• P0128 Thermostat Rationality
• P0131 O2 Sensor 1/1 Circuit Low
• P0135 O2 Sensor 1/1 Heater Performance
• P0137 O2 Sensor 1/2 Circuit Low
• P0141 O2 Sensor 1/2 Heater Performance
• P0148 High Pressure Common Rail (HPCR) Fueling Error Checksum
• P0169 Water In Fuel (WIF) Light On Too Long
• P0191 Fuel Rail Pressure Sensor Performance
• P0192 Fuel Pressure Sensor Voltage Too Low
• P0193 Fuel Pressure Sensor Voltage Too High
• P0196 Engine Oil Temperature Sensor Circuit Range/Performance
• P0197 Engine Oil Temperature Sensor Circuit Low Input
• P0198 Engine Oil Temperature Sensor Circuit High Input
• P0201 Injector #1 Control Circuit
• P0202 Injector #2 Control Circuit
• P0203 Injector #3 Control Circuit
• P0204 Injector #4 Control Circuit
• P0205 Injector #5 Control Circuit
• P0206 Injector #6 Control Circuit
• P0217 Decreased Engine Performance Due To Engine Overheat Condition
• P0219 Engine Overspeed Condition
• P0230 Fuel Pump Primary Circuit
• P0231 Fuel Pump Secondary Circuit Low
• P0232 Fuel Pump Secondary Circuit High
• P0234 Turbocharger Over-boost Condition
• P0236 Turbo/Super Charger Boost Sensor A Circuit Range/Performance
• P0237 Turbo/Super Charger Boost Sensor A Circuit Low
• P0238 Turbo/Super Charger Boost Sensor A Circuit High
• P0243 Wastegate Pressure Control PWM
• P0251 CP3 Pump Regulator Control
• P0261 Cylinder #1 Injector Circuit Low
• P0262 Cylinder #1 Injector Circuit High
• P0263 Cylinder #1 Contribution/Balance
• P0264 Cylinder #2 Injector Circuit Low
• P0265 Cylinder #2 Injector Circuit High
• P0266 Cylinder #2 Contribution/Balance
• P0267 Cylinder #3 Injector Circuit Low
• P0268 Cylinder #3 Injector Circuit High
• P0269 Cylinder #3 Contribution/Balance
• P0270 Cylinder #4 Injector Circuit Low
• P0271 Cylinder #4 Injector Circuit High
• P0272 Cylinder #4 Contribution/Balance
• P0273 Cylinder #5 Injector Circuit Low
• P0274 Cylinder #5 Injector Circuit High
• P0275 Cylinder #5 Contribution/Balance
• P0276 Cylinder #6 Injector Circuit Low
• P0277 Cylinder #6 Injector Circuit High
• P0278 Cylinder #6 Contribution/Balance
• P0279 Cylinder #7 Injector Circuit Low
• P0280 Cylinder #7 Injector Circuit High
• P0281 Cylinder #7 Contribution/Balance
• P0282 Cylinder #8 Injector Circuit Low
• P0283 Cylinder #8 Injector Circuit High
• P0284 Cylinder #8 Contribution/Balance
• P0297 Vehicle Overspeed Condition
• P0298 Engine Oil Overtemperature Condition
• P0299 Turbo/Supercharger Under Boost
• P0300 Random Misfire Detected
• P0301 Cylinder #1 Misfire Detected
• P0302 Cylinder #2 Misfire Detected
• P0303 Cylinder #3 Misfire Detected
• P0304 Cylinder #4 Misfire Detected
• P0305 Cylinder #5 Misfire Detected
• P0306 Cylinder #6 Misfire Detected
• P0307 Cylinder #7 Misfire Detected
• P0308 Cylinder #8 Misfire Detected
• P0335 Crankshaft Position (CKP) Sensor A Circuit
• P0336 Crankshaft Position (CKP) Sensor A Circuit Range/Performance
• P0337 Crankshaft Position (CKP) Sensor Voltage Too Low
• P0338 Crankshaft Position (CKP) Sensor Voltage Too High
• P0340 Camshaft Position (CMP) Sensor A Circuit (Bank 1 or single sensor)
• P0341 Camshaft Position (CMP) Sensor A Circuit Range/Performance (Bank 1 or single sensor)
• P0381 Glow Plug/Heater Indicator Circuit (Wait To Start Lamp Inoperative)
• p0400 Egr System Flow Mali Function
• P0401 Exhaust Gas Recirculation Flow Insufficient Detected
• P0402 Exhaust Gas Recirculation Flow Excessive Detected
• P0403 Exhaust Gas Recirculation Control Circuit
• P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
• P0405 Exhaust Gas Recirculation Sensor A Circuit Low
• P0406 Exhaust Gas Recirculation Sensor A Circuit High
• P040b Exhaust Gas Recirculation Temperature Sensor 1 Circuit Performance
• P040c Exhaust Gas Recirculation Temperature Sensor 1 Circuit Low
• P040d Exhaust Gas Recirculation Temperature Sensor 1 Circuit High
• P0420 Catalyst Efficiency Bank 1
• P0460 Fuel Level Sensor A Circuit
• P0461 Fuel Level Unit No Change Over Time
• P0462 Fuel Level Sensor A Circuit Low Input
• P0463 Fuel Level Sensor A Circuit High Input
• P0470 Exhaust Pressure Sensor
• P0471 Exhaust Pressure Sensor Range/Performance
• P0472 Exhaust Pressure Sensor Low Input
• P0473 Exhaust Pressure Sensor High Input
• P0477 Low Voltage On The Engine Brake Driver
• P0478 High Voltage On The Engine Brake Driver
• P0480 Fan 1 Control Circuit
• P0483 Fan Speed
Old Sep 18, 2012 | 09:21 PM
RamGazer's Avatar
10 Year Member
• P0487 Egr Airflow Throttle Control Circuit A Open
• P0488 Egr Airflow Throttle Control Circuit Performance
• P0489 Egr Control Circuit Low
• P0500 Vehicle Speed Sensor A
• P0501 Vehicle Speed Sensor 1 Performance
• P0513 Invalid Skim Key
• P0514 BAT Temperature Sensor Rationality
• P0516 Low Voltage At The BAT Temp Sensor
• P0517 High Voltage At The BAT Temp Sensor
• P051b crankcase Pressure Sensor Circuit Range/performance
• P051c Crankcase Pressure Sensor Circuit Low
• P051d Crankcase Pressure Sensor Circuit High
• P0521 Oil Pressure Switch Rationality
• P0524 Oil Pressure Too Low
• P0528 Fan Speed Sensor Circuit No Signal
• P0532 A/C Sending Unit Volts Too Low
• P0533 A/C Sending Unit Volts Too High
• P0541 Low Voltage On The #1 Intake Air Heater Relay
• P0542 High Voltage On The #1 Intake Air Heater Relay
• P0545 Exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
• P0546 Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
• P0562 System Voltage Low
• P0563 System Voltage High
• P0565 Cruise Control ON Signal
• P0566 Cruise Control OFF Signal
• P0567 Cruise Control RESUME Signal
• P0568 Cruise Control SET Signal
• P0569 Cruise Control COAST Signal
• P0572 Low Voltage Detected At The Brake Switch
• P0573 High Voltage Detected At The Brake Switch
• P0580 Low Voltage Detected At The Speed Control Switch
• P0581 Low Voltage Detected At The Speed Control Switch
• P0585 Speed Control Switch 1/2 Correlation
• P0592 Speed Control Switch 2 Circuit Low
• P0593 speed Control Switch 2 Circuit High
• P0601 internal Memory Checksum Invalid
• P0602 Checksum Error
• P0603 Internal Control Module CAM Error
• P0604 ECM Software Error
• P0605 Powertrain Control Module Read Only Memory (ROM) Error
• P0606 ECU/PCM Processor
• P0607 ECM Internal Failure
• P061a Etc Level 2 Torque Performance
• P061c Etc Level 2 Rpm Performance
• P0611 Fuel Injector Control Module Performance
• P0620 Generator 1 Control Circuit
• P0622 Generator Field Not Switching Properly
• P0623 Generator Lamp Control Circuit
• P0628 Low Voltage Detected At The Fuel Lift Pump Relay
• P0629 High Voltage Detected At The Fuel Lift Pump
• P062c Etc Level 2 Mph Performance
• P0630 VIN Not Entered Error
• P0633 SKIM Secret Key Not Entered
• P063c Generator Voltage Sense Low
• P063d Generator Voltage Sense High
• P0642 Low Voltage At The #2 Sensor Supply Circuit
• P0643 High Voltage At The #2 Sensor Supply Circuit
• P0645 A/C Clutch Relay Control Circuit
• P0646 Low Voltage Detected At The A/C Clutch Relay
• P0647 Voltage Detected At The A/C Clutch Relay
• P0649 Cruise Control Lamp Control Circuit
• P0652 Low Voltage At The #1 Sensor Supply Circuit
• P0653 High Voltage At The #1 Sensor Supply Circuit
• P0657 Actuator Supply Voltage A Circuit Open
• P065a Generator System Performance
• P0670 Glow Plug Module Control Circuit
• P0671 Cylinder 1 Glow Plug Circuit
• P0672 Cylinder 2 Glow Plug Circuit
• P0673 Cylinder 3 Glow Plug Circuit
• P0674 Cylinder 4 Glow Plug Circuit
• P0675 Cylinder 5 Glow Plug Circuit
• P0676 Cylinder 6 Glow Plug Circuit
• P0677 Cylinder 7 Glow Plug Circuit
• P0678 Cylinder 8 Glow Plug Circuit
• P0683 Glow Plug Control Module to PCM Communication Circuit
• P0698 Accelerator Pedal Position Sensor (APPS) Supply Voltage Too Low
• P0699 Accelerator Pedal Position Sensor (APPS) Supply Voltage Too High
• P06a4 Sensor Reference Voltage 4 Circuit Low
• P06a5 Sensor Reference Voltage 4 Circuit High
• P0700 Transmission Control System (MIL Request)
• P0703 Brake Switch B Input Circuit
• P0711 Trans Temp Sensor, No Temp Rise After Start
• P0712 Trans Temp Sensor, Voltage Too Low
• P0713 Trans Temp Sensor, Voltage Too High
• P0720 Low Output Speed Sensor – RPM Above 15MPH
• P0748 Pressure Solenoid Control/Trans Relay Circuits
• P0830 Clutch Pedal Switch A Circuit
• P0833 Clutch Pedal Switch B Circuit
• P0850 P/N Switch Performance
• P0868 Governor Pressure Sensor Volts Too High
• P0869 Governor Pressure Sensor Volts Too Low
• P0882 Trans 12 Volt Supply Relay Control Circuit Too Low
• P0883 Trans 12 Volt Supply Relay Control Circuit Too High
• P0973 Transmission Overdrive Circuit Voltage Too Low
• P0974 Transmission Overdrive Circuit Voltage Too High
• P1000 OBD Systems Readiness Test Not Complete
• P1001 KOER Not Able To Complete, KOER Aborted
• P1102 Mass Air Flow Sensor In Range But Lower Than Expected
• P1148 Generator 2 Control Circuit
• P1149 Generator 2 Control Circuit High
• P115A Low Fuel Level - Forced Limited Power
• P1184 Engine Oil Temperature Sensor Out Of Self-Test Range
• P125a Power Enable Control Circuit Low
• P125b power Enable Control Circuit High
• P1272 A/C Clutch Control Circuit 2 Low
• P1273 A/C Clutch Control Circuit 2 High
• P1274 A/C Clutch Control Circuit 2 Open
• P1275 A/C Clutch Control Circuit 2 Overcurrent
• P1277 Starter Control Circuit 2 Low (tipm)
• P1278 Starter Control Circuit 2 High (tipm)
• P1279 Starter Control Circuit 2 Open (tipm)
• P127a Starter Control Circuit 2 Overcurrent (tipm)
• P127c Fuel Pump Control Circuit 2 Low (tipm)
• P127d Fuel Pump Control Circuit 2 High (tipm)
• P127e Fuel Pump Control Circuit 2 Open (tipm)
• P0127 Fuel Pump Control Circuit 2 Overcurrent (tipm)
• P1260 Theft Detected, Vehicle Immobilized
• P1284 Aborted KOER — Injector Control Pressure Regulator
• P1335 EGR Position Sensor Minimum Stop Performance
• P1378 FICM Supply Voltage Circuit Low
• P1379 FICM Supply Voltage Circuit High
• P1397 System Voltage Out Of Self-Test Range
• P1408 Exhaust Gas Recirculation Flow Out Of Self-Test Range
• P1464 A/C Demand Out Of Self-Test Range
• P1501 Vehicle Speed Sensor Out Of Self-Test Range
• P1502 Invalid Test — Auxiliary Power Control Functioning
• P1531 Invalid Test — Accelerator Pedal Movement
• P1536 Parking Brake Switch Circuit
• P1610 Interactive Reprogramming Code — Replace PCM module
• P1611 Interactive Reprogramming Code — Diagnose Further
• P1615 Interactive Reprogramming Code — Flash Erase Error
• P1616 Interactive Reprogramming Code — Flash Erase Error, Low Voltage
• P1617 Interactive Reprogramming Code — Block Programming Error
• P1618 Interactive Reprogramming Code — Block Programming Error, Low Voltage
• P1633 Keep Alive Power Voltage Too Low
• P1635 Tire/Axle Out Of Acceptable Range
• P1639 Vehicle ID Block Corrupted, Not Programmed
• P1652 Short To Ground
• P1703 Brake Switch Out Of Self-Test Range
• P1705 Transmission Range Circuit Not Indicating Park/Neutral During Self-Test
Old Sep 18, 2012 | 09:22 PM
RamGazer's Avatar
10 Year Member
• P1725 Insufficient Engine Speed Increase During Self-Test
• P1726 Insufficient Engine Speed Decrease During Self-Test
• P1740 TCC Overdrive Solenoid Performance
• P1756 Governor Pressure Not Equal To Target @ 35-40psi
• P1757 Governor Pressure Above 3psi In Gear With 0MPH
• P1762 Governor Pressure Sensor Offset Volts Too Low or High
• P1779 Eng Torque Delivered to TCM Signal
• P1780 Park/Neutral Pos [PNP] Switch Circ
• P1781 Eng Torque Signal Circ
• P1790 Trans Ctrl Mod Checksum
• P1791 Trans Ctrl Mod Loop
• P1792 Trans Ctrl Mod Reprogrammable Memory
• P1792 ECM to TCM Eng Coolant Signal
• P1793 Trans Ctrl Mod Stack Overrun
• P1795 CAN Bus-Throttle Body Pos
• P1800 TCM Power Relay Ctrl Circ
• P1801 Perf Selector Switch Failure
• P1804 Gnd Ctrl Relay
• P1810 TFP Valve Pos Switch Circ
• P1811 Maximum Adapt and Long Shift
• P1812 Trans over Temp Condition
• P1813 Torque Ctrl
• P1814 Torq Conv Overstressed
• P1815 Trans Range Switch-Start In Wrong Range
• P1816 TFP Valve Pos Sw.-Park/Neutral with Drive Ratio
• P1817 TFP Valve Pos Sw.-Reverse With Drive Ratio
• P1818 TFP Valve Pos Sw.-Drive Without Drive Ratio
• P1819 Internal Mode Switch-No Start\Wrong Range
• P1820 Internal Mode Switch Circ A Low
• P1822 Internal Mode Switch Circ B High
• P1823 Internal Mode Switch Circ P Low
• P1825 Internal Mode Switch-Invalid Range
• P1826 Internal Mode Switch Circ C-High
• P1831 PC Solenoid Power Circ-Low Volts
• P1833 A/T Solenoids Power Circ-Low Volts
• P1835 Kick-Down Switch Circ
• P1836 Kick-Down Switch Failed Open
• P1837 Kick-Down Switch Failed Short
• P1842 1-2 Shift Solenoid Circ Low Volts
• P1843 1-2 Shift Solenoid Circ High Volts
• P1844 Torque Reduction Signal Circ Desired By TCM
• P1845 2-3 Shift Solenoid Circ Low Volts
• P1847 2-3 Shift Solenoid Circ High Volts
• P1850 Brake Band Apply Solenoid Circ
• P1851 Brake Band Apply Solenoid Perf
• P1852 Brake Band Apply Solenoid Low Volts
• P1853 Brake Band Apply Solenoid High Volts
• P1860 TCC PWM Solenoid Circ Electrical
• P1864 Torq Conv Clutch Circ
• P1868 Trans Fluid Life
• P1870 Trans Component Slipping
• P1871 Undefined Gear Ratio
• P1873 TCC Stator Temp Switch Circ Low
• P1874 TCC Stator Temp Switch Circ High
• P1875 4WD Low Switch Circ Electrical
• P1884 TCC Enable/Shift Light Circ
• P1886 Shift Timing Solenoid
• P1887 TCC Release Switch Circ
• P1890 ECM Data Input Circ
• P1890 Throttle Pos Signal Input
• P1891 Throttle Pos Sensor PWM Signal Low
• P1892 Throttle Pos Sensor PWM Signal High
• P1893 Eng Torque Signal Low Volts
• P1894 Eng Torque Signal High Volts
• P1895 TCM to ECM Torque Reduction Circ
• P2000 NOx Trap Efficiency Below Threshold Bank1
• P2001 NOx Trap Efficiency Below Threshold Bank2
• P2002 Particulate Trap Efficiency Below Threshold Bank1
• P2003 Particulate Trap Efficiency Below Threshold Bank2
• P2004 Intake Manifold Runner Ctrl Stuck Open Bank1
• P2005 Intake Manifold Runner Ctrl Stuck Open Bank2
• P2006 Intake Manifold Runner Ctrl Stuck Closed Bank1
• P2007 Intake Manifold Runner Ctrl Stuck Closed Bank2
• P2008 Intake Manifold Runner Ctrl Circ/Open Bank1
• P2009 Intake Manifold Runner Ctrl Circ Low Bank1
• P2010 Intake Manifold Runner Ctrl Circ High Bank1
• P2011 Intake Manifold Runner Ctrl Circ/Open Bank2
• P2012 Intake Manifold Runner Ctrl Circ Low Bank2
• P2013 Intake Manifold Runner Ctrl Circ High Bank2
• P2014 Intake Manifold Runner Pos Sensor/Switch Circ Bank1
• P2015 Intake Manifold Runner Pos Sensor/Switch Circ Range/Perf Bank1
• P2016 Intake Manifold Runner Pos Sensor/Switch Circ Low Bank1
• P2017 Intake Manifold Runner Pos Sensor/Switch Circ High Bank1
• P2018 Intake Manifold Runner Pos Sensor/Switch Circ Interm Bank1
• P2019 Intake Manifold Runner Pos Sensor/Switch Circ Bank2
• P2020 Intake Manifold Runner Pos Sensor/Switch Circ Range/Perf Bank2
• P2021 Intake Manifold Runner Pos Sensor/Switch Circ Low Bank2
• P2022 Intake Manifold Runner Pos Sensor/Switch Circ High Bank2
• P2023 Intake Manifold Runner Pos Sensor/Switch Circ Interm Bank2
• P2024 EVAP Fuel Vapor Temp Sensor Circ
• P2025 EVAP Fuel Vapor Temp Sensor Perf
• P2026 EVAP Fuel Vapor Temp Sensor Circ Low Voltage
• P2027 EVAP Fuel Vapor Temp Sensor Circ High Voltage
• P2028 EVAP Fuel Vapor Temp Sensor Circ Interm
• P2029 Fuel Fired Heater Disabled
• P2030 Fuel Fired Heater Perf
• P2031 Exhaust Gas Temp Sensor Circ Bank1 Sensor 2
• P2032 Exhaust Gas Temp Sensor Circ Low Bank1 Sensor 2
• P2033 Exhaust Gas Temp Sensor Circ High Bank1 Sensor 2
• P2034 Exhaust Gas Temp Sensor Circ Bank2 Sensor 2
• P2035 Exhaust Gas Temp Sensor Circ Low Bank2 Sensor 2
• P2036 Exhaust Gas Temp Sensor Circ High Bank2 Sensor 2
• P2037 Reductant Inj Air Press Sensor Circ
• P2038 Reductant Inj Air Press Sensor Circ Range/Perf
• P2039 Reductant Inj Air Press Sensor Circ Low Input
• P2040 Reductant Inj Air Press Sensor Circ High Input
• P2041 Reductant Inj Air Press Sensor Circ Interm
• P2042 Reductant Temp Sensor Circ
• P2043 Reductant Temp Sensor Circ Range/Perf
• P2044 Reductant Temp Sensor Circ Low Input
• P2045 Reductant Temp Sensor Circ High Input
• P2046 Reductant Temp Sensor Circ Interm
• P2047 Reductant Injector Circ/Open Bank1 Unit 1
• P2048 Reductant Injector Circ Low Bank1 Unit 1
• P2049 Reductant Injector Circ High Bank1 Unit 1
• P2050 Reductant Injector Circ/Open Bank2 Unit 1
• P2051 Reductant Injector Circ Low Bank2 Unit 1
• P2052 Reductant Injector Circ High Bank2 Unit 1
• P2053 Reductant Injector Circ/Open Bank1 Unit 2
• P2054 Reductant Injector Circ Low Bank1 Unit 2
• P2055 Reductant Injector Circ High Bank1 Unit 2
• P2056 Reductant Injector Circ/Open Bank2 Unit 2
• P2057 Reductant Injector Circ Low Bank2 Unit 2
• P2058 Reductant Injector Circ High Bank2 Unit 2
• P2059 Reductant Inj Air Pump Ctrl Circ/Open
• P2060 Reductant Inj Air Pump Ctrl Circ Low
• P2061 Reductant Inj Air Pump Ctrl Circ High
• P2062 Reductant Supply Ctrl Circ/Open
• P2063 Reductant Supply Ctrl Circ Low
• P2064 Reductant Supply Ctrl Circ High
• P2065 Fuel Level SensorB Circ
• P2066 Fuel Level SensorB Perf
• P2067 Fuel Level Sensor B Circuit Low Input
• P2068 Fuel Level Sensor B Circuit High Input
• P2104 Throttle Actuator Control System Forced Idle
• P2121 APPS Conformance Error
• P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
• P2123 Throttle/Pedal Position Sensor/Switch D Circuit High Input
• P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input
• P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
• P2132 Throttle/Pedal Position Sensor/Switch F Circuit Low Input
• P2133 Throttle/Pedal Position Sensor/Switch F Circuit High Input
• P2138 Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation
• P2139 Throttle/Pedal Position Sensor/Switch D/F Voltage Correlation
• P2140 Throttle/Pedal Position Sensor/Switch E/F Voltage Correlation
• P2146 Bank 1 (Cylinders 1-3) Shorted High Or Low
• P2149 Bank 2 (Cylinders 4-6) Shorted High Or Low
• P2199 Intake Air Temperature 1/2 Correlation
• P2227 Barometeric Pressure Sensor Rationality
• P2228 Barometric Pressure Circuit Low
• P2229 Barometric Pressure Circuit High
• P2262 Turbo/Super Charger Boost Pressure Not Detected — Mechanical
• P2263 Turbo/Super Charger System Performance
• P2266 Water In Fuel (WIF) Sensor Voltage Too Low
• P2269 Water in Fuel Condition
• P2284 Injector Control Pressure Sensor Circuit Range/Performance
• P2285 Injector Control Pressure Sensor Circuit Low
• P2286 Injector Control Pressure Sensor Circuit High
• P2287 Injector Control Pressure Sensor Circuit Intermittent
• P2288 Injector Control Pressure Too High
• P2289 Injector Control Pressure Too High — Engine Off
• P2290 Injector Control Pressure Too Low
• P2291 Injector Control Pressure Too Low — Engine Cranking
• P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
• P242b Exhaust Gas Temp Sensor Circuit Performance - Bank 1 Sensor 3 -diesel
• P242c Exhaust Gas Temperature Sensor Circuit Low- Bank 1 Sensor 3
• P242d Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 3
• P242f Diesel Particulate Filter Restriction - Ash Accumulation
• P244a Diesel Particullate Filter Differential Pressure Too Low
• P244d Exhaust Temperature Too High For Particulate Filter Regeneration Bank 1
• P2453 Diesel Particulate Filter Pressure Sensor A Circuit Performance
• P2454 Diesel Particulate Filter Pressure Sensor A Circuit Low
• P2455 Diesel Particulate Filter Pressure Sensor A Circuit High
• p2457 Exhaust Gas Recirculation Cooling System Performance
• P245a Egr Cooler Bypass Control Circuit /open
• P245c Egr Cooler Bypass Control Circuit Low
• P245d Egr Cooler Bypass Control Circuit High
• P2463 Diesel Particulate Filter - Soot Accumulation
• P2503 Charging System Output Low
• P2504 Charging System Output High
• P2509 Ecm/pcm Power Input Signal Intermittent
• P254c PTO Speed Selector Sensor Circuit Low
• P254d PTO Speed Selector Sensor Circuit High
• P2579 Turbocharger Speed Sensor Circuit Performance
• P2580 Turbocharger Speed Sensor Circuit Low
• P2609 Intake Air Heater System Performance
• P268c Cylinder 1 Injector Data Incompatible
• P268d Cylinder 2 Injector Data Incompatible
• P268e Cylinder 3 Injector Data Incompatible
• P268f Cylinder 4 Injector Data Incompatible
• P2690 Cylinder 5 Injector Data Incompatible
• P2691 Cylinder 6 Injector Data Incompatible
• P2457 EGR Cooler Range/Performance
• P2502 Charging System Error
• P2509 Powerdown Data Lost Error
• P2552 FICMM Circuit — Throttle/Fuel Inhibit Circuit
• P2607 Low Voltage At The #2 Intake Air Heater Relay
• P2608 High Voltage At The #2 Intake Air Heater Relay
• P2609 No Voltage Drop Seen From Intake Air Heaters
• P2614 Camshaft Position Output Circuit
• P2617 Crankshaft Position Output Circuit
• P2623 Injector Control Pressure Regulator Circuit
• P2769 Transmission TCC Control Circuit Low
• P2770 Transmission TCC Control Circuit High
• P2a00 O2 Sensor 1/1 Circuit Performance
• P2a01 O2 Sensor 1/2 Circuit Performance
• U0001 Can C Bus
• U0101 Lost Communication With Tcm
• U010c Lost Communication With Turbocharger/supercharger Control Module
• U0121 Lost Communication With Anti-lock Brake Module
• U0141 Lost Communication With Fcm (tipm)
• U1403 Implausible Fuel Level Signal Received
• U1412 Implausible Vehicle Speed Signal Received
• U1421 Implausible Ignition Key Off Time Received
• U0100 Lost Communication With ECU/PCM A
• U0101 Lost Communication With TCM
• U0105 Lost Communication with FICM
• U0155 Lost Communication with Instrument Cluster
• U0306 Software Incompatibility with Fuel Injector Control Module
• B1213 Less than two keys programmed to the system
• B1342 ECU damaged (EEPROM in PCM not working, replace PCM)
• B1600 PATS Ignition Key Transponder Signal Is Not Received
• B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
• B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
• B1681 PATS Transceiver Module Signal Is Not Received
• B2103 Antenna Not Connected
• B2431 Transponder Programming Failed
Old Sep 19, 2012 | 07:52 AM
jhenson's Avatar
RamGazer.......I think you forgot one.
That's a pretty comprehensive list....should be helpful to others in the future.
DJ Turbo.
Oct 13, 2011 09:11 PM
David Kee
Oct 11, 2003 08:33 AM
FastSS
Sep 8, 2003 01:47 AM
FastSS
Jan 8, 2003 05:53 PM
TurboAZ
Oct 11, 2002 12:34 AM
