Driving Lights
Old Aug 27, 2004 | 10:32 AM
triplenickel's Avatar
Driving Lights
OK guys I need some help on a goofy one. 2 weeks back I installed some KC slim lites on my bumper and they worked great, install was nice and easy. But now they don't work and it has me scratching my head. I am using my high beam wire to fire the relay, fairly straight forward system. The relay works well, it seems to be doing it's thing but here is where it gets wierd. Neither of my lights work, but both of them have power going through the bulb and out the ground wire. When I use my light tester on the ground wire it is hot, it will go dead if I unplug the power wire to the bulb. Both lamps do it independantly, but when I pull the bulbs and run 'em right off the batt they light up nicely. Any idea what's up? Could my relay be fried, maybe the contact on the high amperage side is insufficient to light the lamps but enough to light my test light?
Old Aug 27, 2004 | 11:35 AM
DuaneWKKC's Avatar
Check ground..... A bad ground will still read voltage on both sides of the bulb, but you will not have any current flow, meaning your lights wont light.
good luck.
DuaneWKKC
Old Aug 27, 2004 | 12:16 PM
The wierd thing is even when I disconnect the ground wire from the chassis, there is still power there.
Old Aug 27, 2004 | 12:17 PM
SuperGewl's Avatar
Yeah what DuaneWKKC said. If what you said is correct, then you don't have a ground. You should NOT have 12v on the ground side of the lamps at any time. What is happening is when you use one of those light testers you groung on side and then check for hot, whick is exactly what you get HOT 12v on the ground side of the lamps.
Run your ground wirh directly to the batteries to make sure you don't have that problem again.
Old Aug 27, 2004 | 03:30 PM
I think you guys are on to something. I ran a jumper wire quickly at lunch and things seemed to go back to normal. Now I just need to get my brain wrapped around what changed in the last 2 weeks. Thanks for the help.
Old Aug 27, 2004 | 07:44 PM
coobie's Avatar
Check out this site
Go to the tech section on this e-mail site ,check out the wireing diag... site is www.dodge.com/bodybuilder/2004/dr.drmo.pdf.I hope the heck I got that correct..coobie
tntshrekuk
Jun 25, 2008 12:02 PM
msatow
Sep 27, 2006 07:32 PM
CHarlan
Aug 6, 2003 08:40 PM
Pat-3500
Dec 8, 2002 10:45 PM
