Drivers door noise
Old Oct 7, 2004 | 09:27 PM
dcman27's Avatar
Drivers door noise
Hi there everyone. My drivers door made noises from the speaker BASS and I addressed that pretty much with foam behind the door panel, however it appears there are noises comming from the door panel when I go over decent bumps. These noises seem to be eminating from the aluminum decorative trim strip (laramie package). I am asking if anyone has had this problem and a solution. I DO NOT want to go to the dealer since the competence of the mechanics are in question especiall since I am an aircraft mechanic that is taught that mistakes mean dead people.
04 RAM 3500 dually/ cummins/ Laramie/ REGULAR CAB (RARE)
Old Oct 14, 2004 | 12:11 PM
BAD DSL's Avatar
I had similiar noise , fixed it by taking drivers window switch assembly out , cut small piece of fabric the size of trim bezel and reinstall. You can check yours by pressing down on switch panel while radio is on. Hope this helps.
Old Oct 15, 2004 | 06:38 AM
miketriton's Avatar
I have had this problem since they replaced the front drivers side speaker. I have had the dealer try to fix the problem several times, the fix lasts a while then starts again. The noise is more of a creaking as you go over a bump. I found by pressing down hard on the arm rest the noise goes away.
I don't know if this helps but the dealer told me the last time they had heated the plastic hooks on the inside of the door panel and bent them in, I would think to pull the panel closer to the door. This did work. I would rather get a new panel which is what I am fighting for now just as the warranty is running out.
I tried spraying non petroleum based silicon spray pretty much every where, that did not work. I live in hope.
Dynocon
Mar 4, 2008 08:32 PM
agalaczy
24
Dec 21, 2007 07:23 AM
Artcabinets
Oct 13, 2006 07:30 PM
TXPOWER
Mar 10, 2005 04:06 PM
Hondasucks
Dec 17, 2004 09:05 AM
