Death wobble dually?
Old Feb 18, 2006 | 10:18 PM
06dually's Avatar
Once again can anybody verify this condition happening to a dually?? I know it can affect any truck...but specifically has it happened to a dually?
Old Feb 18, 2006 | 11:18 PM
singleturnout's Avatar
my 2000 dually does it ive gone through 3 track bars in the past year
MINES A 4X6
Old Feb 19, 2006 | 07:21 AM
sherman's Avatar
Are you 2x6 or 4x6?
Old Feb 19, 2006 | 08:01 AM
hammerjammer's Avatar
My 05 dually has experienced two episodes of death wobble in the last 6 weeks.,both times I was towing a trailer loaded with horses.I was running 65/70 and hit a big dip in the pavement and the truck just went crazy,trailer whipping side to side felt like the wheels were coming off.This is a scary and I believe very dangerous
problem,I'm aware that it happens with other trucks,but I believe the Dodge has some inherent design problems or the design is ok,and they use cheap parts.I had pretty much ignored the Death wobble posts until it happened to me.
Old Feb 19, 2006 | 08:08 AM
To follow up,my truck is bone stock,70k miles,the tires are wearing correctly,steering is tight,no pull in either direction,I suspect the front shocks may be worn out, it bangs pretty hard over moderate bumps.
Old Feb 19, 2006 | 10:23 AM
06dually's Avatar
Got a 4x4 and hammajamma you got me freaked out now! Were you pulling a gooseneck or bumper pull?? I will be pulling a long gooseneck loaded with anywhere form 10k to 20k plus...Guess I bought the wrong truck, I don't want ta die!!
Old Feb 19, 2006 | 10:38 AM
yep.carry a change of underwear with you.hahaha.I was pulling a 3 horse Gn with two horses,abt. 7 or 8k. this has never happened not towing,but then I don't drive much without towing.lol.My 03 3500,4x4,srw,I drove 153k and never had any DW. You should be ok ,just watch for those dips and bumps in the road.
Old Feb 19, 2006 | 10:48 AM
06dually's Avatar
Well I'm gonna have to just take it easy and be careful then. In the past I've always kinda took it easy with those kind of loads anyway...about 55-65 depending on load.
Old Feb 19, 2006 | 12:31 PM
The 06 may not have this problem. I think they have changed the suspension and steering somewhat for 06.,Wonder why?? lol
Old Feb 19, 2006 | 08:51 PM
06dually's Avatar
I hope your right!
Old Feb 19, 2006 | 10:07 PM
CATCRACKER2's Avatar
yea death wobble can happen with a dually my 97 did. my o3 srw did.
1st time it happens on this truck i will put new oem steering stabalizer and thuren track bar
Old Feb 19, 2006 | 10:13 PM
strokethis600's Avatar
Mine does/did the same thing. took it to a alignment guy and my steering gear was wore out. had to replace the steering box. from what he said the stock steering box is actually a GM unit that dodge buys. the unit is not big enought to handle the heavy front ends of the cummins, they use the same box for all the trucks 1500 through 3500. something has got to change.
Old Feb 19, 2006 | 10:50 PM
goose2's Avatar
i HAVN'T HURD OF THIS HAPPINING ON AN 06 YET! HAS ANYBODY HURD OF AN 06 DEATH WOBBLE?
Old Feb 20, 2006 | 08:32 PM
Seeder's Avatar
The only experience with a DW is on our 96 Ford PS Dually that would go into a DW every so often. After I inspected the front end I found the steering dampner to be shot, replaced and have not a problem since.-Frog
Old Feb 20, 2006 | 10:48 PM
abc4yew's Avatar
Guys, I've never had DW on my dually and if anyone should have it would be me. Heavy loads off road on logging roads.....rock solid. 03's have a better track bar than 04 and 05's I've heard. The cure is a good set of shocks Bilstein or better....not ranchos. I had Ranchos on my F350 04 and it DW on rollers so I removed the steering stabilizer and it was ok....That thing was a piece of junk off a pinto. There is a steering box brace that does wonders....If I had a hint of a problem it would be on there....do a search and let us know. I want to put that brace on as it supposedly stops some front end vibration and solves some tire wear problems. ks
