De-badging Problems
Old Aug 2, 2010 | 09:02 PM
Maverick2001's Avatar
Getting Closer
Ok I used terpentine on it and let it soak for about 10 min and it has now turned into a more "Rubbery" (is that a word) texture rather than the hard glue that it was. I can't do anything with it until I get home on wednesday but I think I am going to try the 3M adhesive remover and if that doesn't work I guess I'll try the 3M eraser wheel.
Thanks everyone for the comments
Dave
Old Aug 4, 2010 | 07:41 PM
rip 112's Avatar
If you havent got it yet I would suggest putting a heat lamp on it for awhile then trying some adhesive remover.
Old Aug 4, 2010 | 08:01 PM
I tried using a hair drier on it to try and loosen it up (I don't think I'll hear the end of that for a while)) and it got hot enough I couldn't touch the door, but it didn't do a thing to loosen the glue. Now that it has soften up a little I may try heat again my wife picked me up a can of 3M adhesive remover so as soon as I get home tomorrow night I may go back to work on it.
thanks again for all the advice.
Dave
Old Aug 5, 2010 | 08:16 AM
pwknapp's Avatar
Hair dryer, lighter fluid, teflon spatula. No damage to paint or clear coat. Then wax on, wax off.
Old Aug 5, 2010 | 12:49 PM
steelblitzkrieg's Avatar
DTR Detective
Don't know if it was mentioned but Denatured Alcohol won't harm paint/clearcoat. I used the citric acid version of goof-off for mine.
Old Aug 7, 2010 | 10:34 PM
No Go!
Originally Posted by whiteeye42
Have you tried lacquer thinner if it works just make sure you wash it with soap and water after your done
Do not try this! It will eat the clear coat!
Luckily I tried it in a small area in the bed.
Old Aug 7, 2010 | 11:41 PM
edd209's Avatar
the 3M eraser will not harm paint. i just did a tacoma de-badge last weekend and have done 4-5 dodges myself with one. unless they put the badges back on with something that turned hard like a super glue, the fishing line or dental floss should slice them right off. then you can soften up the left over adhesive with 3M adhesive remover(a light solvent) or rub off with the eraser wheel- use a slow speed drill and dont sit in one spot and generate a lot of heat!!!! also make sure to clean the area first. i used glass cleaner and a micro fiber towel. the dirt and eraser wheel would dull paint/scratch.
Colo_River_Ram's Avatar
With age comes the cage
I believe some-one said that would be a little hot
Try some toluene in an inconspicuous place like in a small area in the bed.
Old Aug 7, 2010 | 11:58 PM
I figured you were right that is why I tried it in the bed first. I can't find anywhere that carries toulene around here.
Old Aug 8, 2010 | 12:18 AM
No Lowe's/Homer/Hardware/paint stores? my town of 2,000 has it at the lumber yard and the True Value store in the paint section...
Did you try the part store for the 3M adhesive remover ? Do you have any (vinyl) sign shops in town they might have something that would work..
If my memory serves me correct your town is not much bigger than mine.. Our group was coming back from a river trip up north and we ended up in a "Idaho Spud Field" with a convoy of trucks/trailer/rafting gear trying to find the shortcut to Jackson Hole Wy
Old Aug 8, 2010 | 02:57 AM
edd209's Avatar
[QUOTE=Colo_River_Ram;2817702]I believe some-one said that would be a little hot
this referring to the 3M rubber wheel?
Old Aug 8, 2010 | 07:22 AM
kreynolds's Avatar
Give vegetable oil a try. I've used it on some stubborn adhesives before and it worked better than anything else I had tried.
Old Aug 8, 2010 | 09:04 AM
k4jjm's Avatar
Have you tried WD-40? I've had pretty good luck removing adhesive residue with it. It may or may not help with your particlar application.
I removed the rubber moulding from a VW Jetta not long ago...same glue residue left behind. I used the W-40 and it helped, but was still a lot of work. I was able to remove all the glue then wash the WD-40 oil off with soap & water.
Good Luck!
Old Aug 8, 2010 | 01:51 PM
It was a referenced to a post a I made to Maverick2001 (#10), He replied to this with his results in post # 24.. My "hot" reference was of a chemical nature not of the physical nature..
Old Aug 8, 2010 | 03:49 PM
edd209's Avatar
lol ok. i was thinking someone was layin into the wheel if you getting things hot.
