Changing Headlight Bulbs
So, um.....how in the heckare the headlight bulbs changed out?
There is literally no room to even to get the sockets, or the bulbs!
Do I have to pull the headlamp assembly out or what?
Any input, info, or suggestions?
2 bolts in front, 1 nut in the wheel well behind a rubber gasket thingie, all 8 mm i believe, or maybe 10 mm, cant remember. undo all of them then take a wide screw driver wrapped in a rag and use it to pop the headlight assembly out by placing it between the fender and assemply and gently prying it out. carefull not to chip the paint.
HEADLAMP UNIT
REMOVAL
(1) Disconnect and isolate the battery negative
cable.
(2) Remove the push pins attaching the seal to the
fender.
(3) Remove the bolts attaching the headlamp unit
to the fender (Fig. 11).
(4) Remove the bulb sockets from the headlamp
unit
(5) Separate headlamp unit from vehicle.
1 - SEAL
2 - PUSH PIN
3 - SCREW
4 - HEADLAMP UNIT
REMOVAL
cable.
fender.
unit
1 - SEAL
2 - PUSH PIN
3 - SCREW
4 - HEADLAMP UNIT
Thanks for the info guys!
I just finished and it took about 30 minutes, to swap out 4 bulbs: 2 headlights and 2 fog lights.
I swapped in PIAA bulbs and will have to wait another 3-4 hours to test them out in the dark.....
CTD NUT
19
Apr 15, 2005 05:58 AM
My 03 HO
Jun 16, 2003 02:38 PM
