Cab light replacement
Old Jul 22, 2010 | 12:44 PM
WL.'s Avatar
WL.
I'm fixin to put Recon replacement cab lights on as the stockers have began the dreadful leaking. I haven't pulled any lights yet, but was wondering if there are connectors on the wires or will I have to cut the lines and rewire? Would like to know if it will take an hour or three and get the right parts from the basement without making a thousand trips. Thanx in advance and have a great weekend ya'll.
Old Jul 22, 2010 | 03:39 PM
2171CTD's Avatar
They are direct replacement for factory cab lights. Plug and play
Old Jul 23, 2010 | 01:32 AM
Sasqoutch's Avatar
What he said, i went to the local homedepot and bought some nylon/plastic washers to replace the rubber ones that started cracking within 2 months and letting moister into the lights.
Old Jul 23, 2010 | 06:33 AM
WL.'s Avatar
WL.
Thanx to both of you. I was thinking about putting a spot of silicone where the screw/rubber connects to the cab. In theory, the LED's should not burn out, so there should not be a reason to ever take them off again. I figure that as long as I just put a dab on there, if I ever did have to remove them, it shouldn't be too difficult. Thanx again ya'll and have a great HOT weekend.
Old Jul 23, 2010 | 05:43 PM
2171CTD's Avatar
No problem bud. Id put some silicone around the edge of the lenses. Some get leaks without it.
Old Jul 24, 2010 | 11:23 AM
Rednecktastic's Avatar
Some advice:
Lightly rub a little grease on the bottom of the light before siliconing it. That's what I do if I do not want a permanent type of seal.
You can scrape it off the truck with a plastic scrapper if you ever need to remove it.
Does the Recon kit come with a template? I really want to install them. I don't have cab lights stock.....
Old Jul 25, 2010 | 12:47 AM
2171CTD's Avatar
The Recon kit does not have the template. Buy a set of cab lights from the dealer and it will include the template along with the wiring you are going to need.
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
SolidJunkMM
Oct 29, 2008 08:53 AM
MRFD715
Jun 15, 2008 02:04 PM
rockittboy
Jun 5, 2006 08:28 PM
