A/C Odor Problem
Old Jul 10, 2004 | 12:13 AM
Riverman777's Avatar
Question A/C Odor Problem
Here lately I've noticed when I first turn the A/C on, the there's a funky odor. I don't smoke, but the truck sits a month at a time when I'm gone to work. It smells like it's in the ducts. An old smell sorta. Is there some way to clean a filter or something to freshen it up? Or maybe access the condenser coil and clean it with some cleaner or something. Any help would be appreciated.
Old Jul 10, 2004 | 06:26 AM
Hounddog's Avatar
There is a D.C. part number for a cleaner/deoderiozer.Also has instuctions.When you do use AC run it on fresh as much as possable.Its also covered under the 3/36 basic warranty.
Old Jul 10, 2004 | 08:22 AM
surfram's Avatar
Switch the dial to vent (not recirculate) before shutting down. I think that it keeps the system open so it can dry out.
Old Jul 10, 2004 | 09:06 PM
Thanks guys.
Old Jul 11, 2004 | 01:28 AM
Nevada's Avatar
Surfram is absolutely correct. When you run the A/C in recirculate or "max" mode, water condenses in the plenum. When you shut down, especially when it is warm outside, mildew starts to grow in your plenum as a result of this water or dampness. The classic symptom is a baby puke smell when you first fire up the A/C or vent.
This is easy to prevent, really easy if you live in a dry climate. A mile or two before you reach your destination switch the A/C to "normal" mode and the dry outside air will dry out the plenum. If you live in a humid climate it will take more than a mile or two.
Old Jul 11, 2004 | 11:55 AM
Bigredmachine's Avatar
You might try to shoot a little Lysol in the air intake for the heater, it will kill the mold that's causing the odor. Of course then you have to smell the Lysol
Old Jul 11, 2004 | 12:31 PM
Hounddog's Avatar
Lysol does not last very long or kill the mold spores.There is a FACTORY deorderizer that WORKS.Can be bought or ordered through your D.C. dealer.
Old Jul 12, 2004 | 07:26 AM
ppsi's Avatar
I get a sweet, pungent odor. I cannot imagine it caused by mold as it has been there since new. It starts after running in recirculate for a few minutes and doesn't start right away. It is very annoying so any answers are appreciated.
Old Jul 12, 2004 | 04:19 PM
Hounddog's Avatar
Well leave it on recir.and it will get moldy and the sweet odor will go away.
Old Jul 17, 2004 | 06:19 AM
The Dodge Service Rep told me to spray Lysol into the intake grill by the wiper blades. She didn't mention anything about a factory deodorizer. I should have asked.
Old Jul 17, 2004 | 02:34 PM
Hounddog's Avatar
The factory stuff is a mildew destroyer.Its designed to go into the evaporter assy.its NOT JUSt a spray.Has instructions to cycle from cold to hot etc.Lots of TSB's on Caravans etc.that call for this.It works and really does something were the Lysol is just a temp smell good.
Old Jul 17, 2004 | 03:49 PM
Geico266's Avatar
How about bleach and water?
Old Jul 17, 2004 | 05:37 PM
Hounddog's Avatar
There are some chemicals you do not want to get on the evoportor assy or the plastic case.I don't think I'd use bleach.
Old Jul 17, 2004 | 07:28 PM
Lysol is supposed to kill 99.9% of bacteria and mildrew, so if I can it into the condenser coil assy, that would be good. I don't know how easy it is to access though.
Old Jul 17, 2004 | 09:40 PM
SuperGewl's Avatar
Just remember that when YOU break it YOU have to PAY to get it fixed
If you use the DC stuff then it will still be covered under warranty and they can fix it for free
