bugs in new Rams
bugs in new Rams
Hello, I'm thinking on a Ram 2500 CD Quad LB and saw a post on this board regarding what to watch for when you pick out your truck. One mentioned "plugs" and also "counterweight on power steering hose". Are these real issues?
Thanks for a GREAT site!
I've been following this with much interest too:
Plugs instead of tape in the body/cab. I'm not sure this is a real issue, but many prefer the plugs to the tape.
There were some vibes in the steering wheel. The weight fixed some of that, and newer trucks have it. Others have different vibes around 70mph. That seems more serious, but I'm not sure it's widespread.
Exhaust smell in the cab...in the winter I think this was more of an issue.
48RE is supposed to have a thrust washer that's not up to par, according to an aftermarket rebuilder.
Plugs - I didn't even check. I mentioned it to my dealer and they acted like they didn't even know what I was talking about. Worst case, you buy them and stick them in yourself if you think you need them.
PS Counterweight - Mine is a March 04 build and I can't seem to find it - but everyone swears it must be there. I'm going to look again as soon as I get the chance.
The two biggest complaints, IMHO, that people are concerned with seem to be:
1) 70mph vibration - this seems to primarily affect SWB 4x4 AUTO trucks but has been observed in others. It comes on at about 70mph and carries on to 75-80mph before smoothing out again. Some have it worse than others. Some claim a front drive shaft fixes it. Others say it's a rear drive shaft. Others got a new transfer case. There's even one (Hoot) who got rid of it by changing his exhaust system, rear diff fluid and re-calibrating his ECM for larger tires.
2) Fuel mileage - unlike the 70mph vibe problem, this one strikes across the board (no particular models affected - although 6-spds are probably better than autos). Of course, there are exceptions, but I think pretty much most 325/600 owners are a little (or a lot) disappointed with the mileage. The current cost of fuel definitely amplifies the problem.
The test drive can quickly flush out the 70mph problem. But, if you ordered the truck and waited 8,10, 12 weeks to get it as some of us did, are you willing to walk away if it vibrates a bit? I guess it boils down to gambling that DC or Cummins will come up with fixes to these problems. I gambled that they will (since I seem to unluckily have both issues with mine).
As the saying goes, "You pays your money and you takes your chances".
Good luck.
Neil
Mine is a 03/03 build. It has the tape in the rocker panels. Since some of these are removed for fitting nerf bars or sidesteps I don't see it as that big of a deal. You can always order the number of rubber plugs needed.
Only smell I get is when sitting stopped for a light or such. You can hit the recirculate air button.
The p/s weight was installed. Right side, front of engine, a 2in or so slotted metal weight on the hose.
No vibration at 2k RPM or 70MPH though as a SB, 4x4 2500 it is the most likely candidate.
Mileage is satisfactory.
No problems, no regrets.
Ed
Ed
Re: Rocker Panel Tape
Originally posted by natstayl
if it starts to peel, I'll see what the dealer says about plugs.
Will the truck fall apart with tape instead of rubber? No.
If I can get rubber plugs instead of tape just by making a fuss, would I do it? %&#$ YES, why NOT??
It should have been done right from the factory. I don't want those holes full of sand, mud, rocks, water, or anything else besides AIR, and I want it to stay that way thank you very much.
Re: Re: Rocker Panel Tape
Originally posted by thejeepdude
It's not a matter of IF, it's a matter of WHEN.
Re: Re: Re: Rocker Panel Tape
holes for the water to drain out and some sand is gonna find its way inside anyway. Sure I plan to ask the dealership for plugs, until then I will keep an eye on the tape edges that's all I'm saying. And while we're making a wish list of things the factory should have provided, be sure to include rear fender liners, and under hood insulation. Nat
Actually, it's on the left side. The "sides" of an engine or vehicle are determined by sitting the vehicle facing forward. The "left" side is on your left, the "right" is on your right. It does not change if you get out of the vehicle and walk around the front to face the vehicle. At that point , the trucks "Left" is on your right. Same idea as the Port and Starboard of a boat.
Neil
Neil,
My truck's build date is March 3, 2004 and has the weight. Driver's side of the engine near the front. Up top, two fair size hoses with one having the weight. The hoses come from the firewall parallel with the brake master cyl. The weight is on the upper of the two. On mine the negative cable from the battery(driver's side) touches the weight. Hope this helps.
Ed
Ed
