Blinkers acting crazy
Old Aug 27, 2012 | 04:55 PM
streetdoc's Avatar
When using the left turn signal it turns on the right blinker, when using the right turn signal sometimes it works, sometimes it doesnt. It's not as bad with the steering wheel up all the way, but still does it, and some days it works normal.
Old Aug 27, 2012 | 09:08 PM
06dodge4x4's Avatar
Not sure if it applies to you, but I got something in the mail that extended the warranty on the turn signal control to 100,000 miles. It mentioned that it might cause the signals to work in reverse. Might be worth a call.
Old Aug 28, 2012 | 06:31 PM
steelblitzkrieg's Avatar
DTR Detective
Bad multi-function switch.
Old Sep 1, 2012 | 04:00 PM
BigDave12768's Avatar
I had same issue. check your trailer plug and wires. Undo the clip on back look at connections. Mine was all green replaced the whole set up. Never happened again.
Old Sep 11, 2012 | 12:20 PM
Kaysee's Avatar
Check out this "How To ..." that member Shorts posted. It may help with your problems.
https://www.dieseltruckresource.com/d...44#post3131344
Chessbay
May 7, 2013 03:07 PM
440_D50
Feb 27, 2007 07:51 PM
cluckmaster
13
Jan 23, 2007 12:43 PM
97-12v
Dec 27, 2005 10:09 PM
