A Bit of info
Old Nov 7, 2008 | 07:36 PM
jman's Avatar
A Bit of info
I am installing a gauge on my 2006, I am trying to get 12 volt + i was thinking the sig lighter would be the best ,, so how the heck does one get to the lighter wires??????? or if some one knows what wire would he hot with 12 volts when the key is on and off when the key is off,,
thanks
jman
Old Nov 7, 2008 | 07:57 PM
snoyes's Avatar
I tied into the fuse block in the engine compartment... I want to say fuse #25, but you need to test those and check (I would run out and check but am deployed, truck is many thousands of miles from here). Can buy one of those cheap little blade fuse tie ins.
Old Nov 7, 2008 | 09:20 PM
bob4x4's Avatar
thanks
jman
Pull the radio bezel..............not an easy task if you have the full ctr cosole
Old Nov 8, 2008 | 07:06 AM
MikeyB's Avatar
I cheated and used the 12v on the electric brake controller for my gauge.
MikeyB
Old Nov 8, 2008 | 08:55 AM
megacabdad's Avatar
Space #40 in the fuse box under the hood...for the cigar lighter...20A
Get one of those double fuse holders with the short piece of wire and butt connector on it from the parts store...
Old Nov 8, 2008 | 11:41 AM
jman's Avatar
thanks
Thanks guys , thats what i will do is tap a fuse ,, i do have to say that i have not seen it that clean under a dash like this truck is ,, my 98 is a mess with wires a stuff.
thanks
j
Old Nov 8, 2008 | 01:01 PM
Foxborough's Avatar
I use the wire that is in the bundle of wires that are by where your left foot rests. I remember it was the pink but I forget what color stripe it was..sorry but it was the same as the cigar lighter closest to the driver. Hope that helps some.
sleblanc386
Jul 7, 2008 04:31 PM
Mark03Ram
Nov 3, 2007 01:40 PM
broncobilly
Mar 17, 2007 12:03 AM
Homestead
Apr 20, 2006 02:09 AM
