Batteries Failing
Old Dec 6, 2021 | 05:46 PM
Hoakieman's Avatar
Batteries Failing
Hi All, My 2009 Cummins keep throwing codes about intermittent power, specifically, P2509 ECM/PCM Power Input Signal Intermittent. My batteries are both at 12.18 volts, but if I leave it for a week the truck won't start. is this a signal I need new batteries? I don't see any dates and they are MOPAR batteries. Not possible they are original???. Anyone have suggestions?
Old Dec 6, 2021 | 10:20 PM
nothingbutdarts's Avatar
One of the two batteries from my 2001 is still in use in a 1996 gas job. Any parts store should be able to load test them and tell you if they are good. 12.18 is low voltage though. How long had they been sitting when taking the above voltage?
Old Dec 7, 2021 | 11:34 AM
Hoakieman's Avatar
My truck had set for about two weeks, then I charged up the batteries and ran the truck up to operating temp on the road. I had received ths code before and I do have a load tester, it read in the bottom of the green. I'm thinking new batteries?
Old Dec 7, 2021 | 07:29 PM
When I load test batteries, they have to hold good for 15 seconds and come back up to almost 12.5 volts after a minute.
Old Dec 7, 2021 | 07:47 PM
Hoakieman's Avatar
Nothingbutdarts, Wow thanks for the advice, I've been doing the load test all wrong! Helps sometimes to read the instructions. I'll recheck my batteries. Great help!
pdogg
Dec 7, 2021 03:04 PM
quick1300r
Jul 3, 2015 04:07 PM
railroaderone
Dec 26, 2013 05:20 PM
billmac
14
Oct 7, 2004 10:40 AM
misterKTM
May 28, 2003 09:42 AM
