ball joint help
ball joint help
OK i lifted my truck 6" this weekend and I'm wanting to replace the ball joints upper and lower they have 88,000 on them and i have had some bad DW. I'm getting sick at some of the prices i have got from 580.00-1428.00. how big of a pain is it to replace the joints and what joints do i need the adjustable ones with 1* camber are just straight joints. I'm going to use Moog. hell half of the shops i talked to don't know is this some the alignment shop is going to need????? help me please
your probably fine with non-adjustables. sounds like your trying to save some $$ and they are expensive, but you could consider the carli uppers ($550). Then you won't have to change them out again soon
since i supplied the labor i still came out ahead versus paying a shop to put moogs in...
iI would do axle u-joints while its all apart also. DW seems to come from any combination of worn front end parts. may also want to check track bar bushings, play in gear box sector shaft, tie rod end slop....
since i supplied the labor i still came out ahead versus paying a shop to put moogs in...iI would do axle u-joints while its all apart also. DW seems to come from any combination of worn front end parts. may also want to check track bar bushings, play in gear box sector shaft, tie rod end slop....
check out red head steering gears for a new gear box, better than oem and only $265 after core refund.
http://www.redheadsteeringgears.com/
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
