balancing Procomp Extreme ATs
Hey all,
Having some trouble with shaking at 55-75. According to Robert at www.innovativebalancing.com , (who is a stand up guy willing to go the extra mile for his customers) a tire balancing machine can balance tires with beads in them as long as the tire doesn't spin so fast as to set the beads in place by centrifugal force. Is there a brand of tire balancing machine that will spin slowly that I can look for to do this.
thanks Jamie
thanks Jamie
A tire balancing machine that spins slowly I have not heard of. When we balance tires with bead locks we select the static type of balance on the machine. What size are the rims and tires? How did they balance your tires? How much weights does each rim has? Did you try switching the tires from front to back and does it still shimmy?
Originally Posted by SuperGewl
OK, forget about balancing your tire and get yourself a set of Centramatic Balancers from Mr. Truck
With these you don't need to balace the tires and they work great
Ok here's an update,
Well after much research and talking to several people, I think I know why my truck is shaking. The two back tires aren't mounted on the wheels properly. I put the entire truck on jack stands today and cranked it, put it in 4WD and let the tires spin at idle. The two fronts spin absolutely perfect. Both back tires wobble as they spin. As far as I can tell the wheel spins straight just the tires are mounted funny causing a wobble as it spins.
Back to the tire shop.
Jamie
Jamie
icrider
Sep 18, 2009 01:21 PM
jboIND
Apr 3, 2008 07:16 PM
getblown5.9
Apr 7, 2006 02:18 PM
Jmac
Mar 15, 2006 11:54 PM
