Ash tray won't close
Old Feb 16, 2008 | 12:31 PM
TurboTed's Avatar
The ashtray on my son's 03 won't stay closed. The spring still works, but it does not stay shut when you push it up closed. I don't see anything broken. Has anyone had this happen, and what did it need? (thanks!)
Old Feb 16, 2008 | 01:02 PM
ddt111's Avatar
I had this happen in my '03. I was at a salvage yard and picked up another ashtray. I popped the old one out to put the new one in. While popping it out, it started working again. No problems since. I recc. pulling it out and cleaning it. Hope it works.
Old Feb 16, 2008 | 01:04 PM
TurboTed's Avatar
What's the trick to taking it out. so I don't break it(LOL)? (Thanks!)
Old Feb 16, 2008 | 01:11 PM
metalbasher's Avatar
You've got something under the tray. I had the same problem, some change had popped out of the ashtray and got underneath. I don't remember the trick to pulling the ashtray out though.
Old Feb 16, 2008 | 01:17 PM
TurboTed's Avatar
I bet he does have change in there, because that's exactly what he uses it for, and it looked pretty full. Thanks! Now- does anyone know how to get the ash tray out??
Old Feb 16, 2008 | 01:28 PM
BradyQB's Avatar
When it is open, pull up on it towards the sky, it is being held in by a little clip type thing molded right into the door of the ashtray, if that makes sense. But be careful because they can break off... That is what I do when I get that problem...
Old Feb 16, 2008 | 04:53 PM
TurboTed's Avatar
Thanks! I'll give it a try.
Old Feb 16, 2008 | 04:58 PM
dropped2500's Avatar
make sure to pull the center piece that has all the change in it out or big mess! HAHAHA
Old Feb 16, 2008 | 05:29 PM
TurboTed's Avatar
I pulled out the tray part. There was nothing dirty, and no change or anything else between it and the actual part that swings out. The actual part that swings out shuts perfectly without the tray in it. When I re-install the tray, it will not stay clipped shut. ???
Old Feb 16, 2008 | 07:36 PM
did you pull the part out that the lid is attached to?
Old Feb 16, 2008 | 08:40 PM
kawiram's Avatar
Mine wont stay shut if I have too much change in it. To weak to hold up much weight I guess.
Old Feb 16, 2008 | 08:50 PM
TurboTed's Avatar
I just pulled out the tray that the ashes or in this case- the change goes in. Are you talking about the part that actually flips opened? That part closes fine when the inside tray is taken out. (I'm not sure how to get that part out.)
Old Feb 17, 2008 | 03:08 PM
Xonid's Avatar
Thanks guys.. my ashtray was also not clipping shut.. I had a small bungie holding it closed.. I just pulled it off and sure enough it had a dime and a fuse behind the tray. works perfectly now..
thanks..
Old Feb 17, 2008 | 04:32 PM
ddt111's Avatar
Glad you fixed it. I figured it would be simple. Mine still works great and that was probaly six months ago.
Old Feb 17, 2008 | 07:10 PM
Turboted..pull the tray out and pull up on the lid part that opens and shuts.. alot of the times something gets stuck in there and will close fine with the tray out...
