Any problems running D load rated tires?
I'm looking to install some BFG Mud Terrain KM2s this week. The 35s are only D load rated. I don't do any heavy hauling, only occ trailering / loads of 2-3k pounds. Has anyone had any problems running non-E rated tires (if not hauling heavily)? Uneven wear?
Comments welcome!
Thanks.
Comments welcome!
Thanks.
I ran BFG 315s (D Rated) on stock wheels for 55k and now run the BFG 285s (D Rated) that come on Power Wagons. I did have a slight cupping wear on the 315s mounted on 8 inch wheels, but not bad and still got 55k out of them. 35s would best on at least 8 1/2 wheels to eliminate any cupping issues.
As long as you do not tow heavy I don't think you will have any problems. From what I have seen on forums there are a lot of people running D Rated 35s on 3 gens.
If you don't haul or pull heavy, you most likely will not have problems. Though the weight rating on the tire may be the same, sidewall flex in the E rated tires will be less. Hence they have D and E rated tires. Especially important for those pulling large trailers, etc. Not so much a factor in your case.
I don't have tires like this so I cannot give first-hand experience. BUT I have seen a lot of posts on here describing that even though the load ratings are the same for weight, the E tires have stiffer side walls than D tires and the 3rd Gen trucks drive and steer better with the E tires. Definitely the case for heavy loads, but for light and empty, not sure if it makes a big difference. I love the way my truck has tight, accurate, and predictable steering. If that feature of my truck was compromised I would be unhappy with it.
No 'mo "D"s
With an unladen or lightly laden truck the "D"s should be fine,especially a mud tire which has thick sidewalls by design. My Bridgestone AT 285-75-16's which I ran on my old '99 blew out on the right front. My total truck weight w/popup camper was 8250# which equals 2075# load per tire. The truck had almost perfect load distribution fore and aft. The Bridgestones were rated at 3305# so I was well under the rated capacity. The tire experienced total separation of tread from the tire body. Within maybe 15-20 secs.,$3300 damage was inflicted to the truck. Make up your own mind. I'm currently running "E" rated Toyo 285's on my '07 and am very pleased.
I had BFG 315s on my 03 and towed up to 12,000lb often. I had no problems ever with them. I might have them on my current truck except I have the TPMS system on this truck which requires that I keep an E-Rated tire with high pressure or else I would have to deal with lights and alarms....
D's are fine. Most folks run their Es with 50 psi (unloaded) to get a softer ride. I run my BFGs at 60-65 psi and have just as nice of a ride while maintaining the max weight rating of the tires. I went from the Rugged Trail 265s to the BFG KO 285s. If I could get a better price on 285 E tires, I would prefer those. It's hard to beat FREE though on the set I have now.
One thing to note: I think generally speaking, a softer D tire will wear faster than the E.
85,000 miles on two sets of d range tires. never had death wobble! no problems! the bfg ta/ko's i run are a 50,000 miles tire- my last set i got 55,000 miles out of them- i assume i will get the same out of the set.
