AC performance mod
Old Jul 3, 2009 | 06:37 PM
  #361
rockcrawler304's Avatar
Originally Posted by Spooler
You don't have to do all of this to get your A/C to work like a champ. Just get a condenser fan and relay. Problem solved. It also quits boiling out the R134 due to excessive high pressures on the high side.
You mean like a separate electrical fan right? I do have an extra one lying around. I may just have to try it and see if there is a temp change. Keeping extra air flow over the condenser should help keep the pressure and temp of the R134A down.
Old Jul 4, 2009 | 03:10 AM
  #362
Spooler's Avatar
Yeap, the ones like are in this thread. They can only be 2" deep. Not enough room for anything thicker. With the fan you can add a little more R134a to the system to make it work even better.
https://www.dieseltruckresource.com/...d-t245620.html
Old Jul 6, 2009 | 06:40 PM
  #363
dott's Avatar
Originally Posted by Dan_K
Home depot has 3/4 barbed ball valves for pex fittings. $4.30.
The barbs measure 5/8" and slid right into the 5/8 circ line. I only did the feed line and will do the return line if needed.
I couldn't bear to read through 26 pages, 12 is enough, but good info.
Dan,
Are you talking about this one?
"HydroPEX H080750 - 3/4" PEX x 3/4" PEX Ball Valve "
http://www.pexsupply.com/HydroPEX-H0...alve-3772000-p
Probably need a couple Tees too...
http://www.pexsupply.com/HydroPEX-H0...-Tee-3727000-p
Pic of the 3/4" valve....
Old Jul 6, 2009 | 09:18 PM
  #364
1985cucv's Avatar
ok so if you do this mod and want more cooling to the backside of the motor you could take out the plug in the back of the motor and tie that into the retun along with 2 valves right? t off the retun in other words and run a line from cylinder 6 correct. i also want to add a coolant filter in here.
Old Jul 7, 2009 | 07:08 AM
  #365
MikeyB's Avatar
Yes, you can tap off the #6 coolant plug on the head for the coolant filter. Checkout Ace's photos (thread #353) for his setup.
MikeyB
Old Jul 7, 2009 | 07:23 PM
  #366
1985cucv's Avatar
so what you do is close the valves off and this is fine where does the coolant go then? instead of going to the heater core it just goes farther forward in the motor to the thermostat housing?
Old Jul 8, 2009 | 05:45 AM
  #367
mastercaster's Avatar
on the 6.7, it goes out the back of the motor, then you install a tee fitting and goes over to the turbo. so your only removing the heater core when the valve is closed. not sure on the 5.9.
Old Jul 8, 2009 | 10:07 AM
  #368
03RAMBUNCTIOUS's Avatar
I watch wind blow...
MAybe my photos will help. .
all these parts used plus more hose clamps.
All those parts make this.
works good for me.
Old Jul 11, 2009 | 06:01 PM
  #369
MikeyB's Avatar
I decided to go ahead and do a coolant bypass for the #6 cylinder. It's cheap and easy to do so why not.
A few parts are needed. Several fittings, hose and hose clamps.
Dorman 56356 5/8" nipple/ 1/2" NPT fitting
Dorman 56387 5/8" Tee fitting (metal)
5/8" heater hose and 4 1.25" hose clamps.
Only problem is the 5/8" metal Tee fitting is hard to find at the autoparts stores and so I ended up ordering it. Everybody has the plastic version but I worried about durability from the heat sitting above the exhaust manifold and turbo.
So now I wait for the fitting to come in for the installation.
MikeyB
Old Jul 11, 2009 | 08:58 PM
  #370
MikeyB
I paid about $40 for the two T fittings shipped, and they were a PAIN to locate. .
Old Jul 12, 2009 | 06:00 AM
  #371
rootercycles's Avatar
A simpler, and maybe a little cheaper would be to use a bypass valve. I'm sure someone has suggested this, but 25 pages is too much for me to look at...
Old Jul 12, 2009 | 07:08 AM
  #372
MikeyB's Avatar
Rockauto has the fitting for less than $7. I went ahead and placed a order with them since I needed some stuff for the Magnum.
MikeyB
Old Jul 12, 2009 | 07:12 AM
  #373
MikeyB's Avatar
One of the members did post about a bypass valve assembly for a Ford. My only concern with this is it's made from plastic, and the long term durability from the heat generated from being near the exhaust manifold and turbo.
MikeyB
Old Jul 12, 2009 | 09:55 AM
  #374
Here's a brass one for under $12. Now the fittings aren't right, and you would have to chase down clamps and ends to place hose on, but this would be simpler and the only thing you would then bypass would be the heater core, keeping the original flow to the block. Of course, I am better pointing theory than doing it...
http://store.silverlakemarine.com/si...p?ITEM=5337463
Old Jul 12, 2009 | 10:18 AM
  #375
Ace's Avatar
Ace
Yaaay!
Now I have a reason to go back and re-visit this. Maybe the stock fitting will not be going back in after all...
