AC performance mod
Old Jul 7, 2008 | 06:17 PM
  #151
cbrahs's Avatar
Originally Posted by Bark
Cbrahs: In tight quarters I usually take the ball valve handles off, cut off most of them and sometimes (if room) even reinstall them upside down. (just to keep em out of the way). They still turn easy enough but in the closed position they dont stick out very far.
C Schomer Some very good points but the reference towards corrosion or sediment pooling in the core dont concern me since I routinely store my truck for months anyway.
I am not worried about space. the 3" bodylift cures that for me! LOL thanks anyways.
Old Jul 7, 2008 | 06:20 PM
  #152
elirandolph's Avatar
Ive got the valve in hand, just waiting for the truck to cool down. I'll let yall know how it turns out.
Old Jul 7, 2008 | 06:27 PM
  #153
BroncoHound's Avatar
Originally Posted by elirandolph
Ive got the valve in hand...
so...you're typing with your tongue? Impressive. Unsanitary, but impressive.
Old Jul 7, 2008 | 06:28 PM
  #154
cbrahs's Avatar
^^^^^^^^ Now that is funny rit there! bout spit my gatorade all over the keyboard
Old Jul 7, 2008 | 07:51 PM
  #155
txfiremedic's Avatar
Got the mod done to mine today, I did both lines but didn't do the bypass. Super Easy Mod, took 5 minutes. Thanks cbrahs!!!
Old Jul 7, 2008 | 09:06 PM
  #156
Matt S's Avatar
Originally Posted by cbrahs
If you have a temp difference on the passenger side vs. the drivers side you might have a blend door problem
You may also be not full on the A/C charge. That was my case.
Old Jul 8, 2008 | 07:05 AM
  #157
Hunter11's Avatar
So if you do this mod can you turn the AC down if it gets to cold in the cab? I use the outside air setting pretty much all the time.
Old Jul 8, 2008 | 07:13 AM
  #158
MikeyB's Avatar
With this mod you won't be able to mix heat with the AC, if that's what you mean. Don't think it's a problem here in Texas in the summer time. When fall comes open the valve to have heat.
MikeyB
Old Jul 8, 2008 | 08:48 AM
  #159
Hunter11's Avatar
The only issue is I leave for work at 5:15 in the morning and I have to turn my AC down about 3 to 4 notches each morning because the AC gets to cold. Now coming home in the afternoon I want it on full cold. So even on the outside air setting I still cannot turn it down early in the morning?
Old Jul 8, 2008 | 09:01 AM
  #160
rip 112's Avatar
Turn the valve on in the morning, turn it off in the evening. Either that or just turn the Max AC button off.
Old Jul 8, 2008 | 11:47 AM
  #161
Hunter11's Avatar
I don't want to have to mess with the valve twice a day. I never use recirculate on the AC so I will assume with running it on fresh air I could still control the temp with the valve installed.
Old Jul 8, 2008 | 12:11 PM
  #162
ssandlin's Avatar
With the valve closed, you'll not be able to change the A/C air temp. With the valve open, the system will function as if the valve was not there.
Old Jul 8, 2008 | 01:06 PM
  #163
Ducman82's Avatar
anyone know what size the presure side port is on the head?
Old Jul 8, 2008 | 07:17 PM
  #164
Highway 4x4's Avatar
Is there a HP or MPG gain with this mod? ;-)
Old Jul 8, 2008 | 07:18 PM
  #165
CowboyDave's Avatar
200-300 hp depending on year.
