abs brake problems
Old Oct 6, 2005 | 09:59 AM
roadrat's Avatar
abs brake problems
After fuelling up last night and leaving the station the dinger went off and the abs light came on, i pulled over as i could here a noise comming from under the hood. I shut the truck off but the noise continued, i opened the hood and the pump for the abs was running, the only way i could get it to stop was to pull the fuse. Anybody else ever have this happen? I am guessing maby some sort of relay is shorting out, any suggestions? I hate going in to the dealers blind, especially with abs problems, could get real expensive. the brakes are working fine, and i was not pressing on the brake pedal when this happened. Thanks guys (& gals)
P.S. no warranty left.
rob
Old Sep 19, 2008 | 06:15 PM
Woodchuck61's Avatar
ABS problems with 139k miles
I did a search and this post is all I came up with. I've got the same symptoms.
Wow, I guess we are lucky, it seems this happens a lot more to Chevy's.
I ordered a complete Hydraulic Control Unit (HCU) today for about $400 and from what I read in the service manual I need a DRB III to test and program or initialize the unit.
Old Sep 20, 2008 | 03:02 PM
Hey Roadrat what was your resolution to this problem?
I got the new HCU but think I'm going to try just changing the electronics module.
Old Sep 20, 2008 | 05:55 PM
D45's Avatar
D45
My truck's ABS/Brake Light was on earlier in the year.
It was not storing a fault code, but was showing that the front driver side ABS sensor was not within range.
I pulled the rotors from both sides and unbolted the ABS sensor in each hub.
I then cleaned the grease off of the tip on the sensor and re-applied some axle grease to the sensor's tip.
One week later the ABS/Brake Lights went off and never came back on!
Old Sep 22, 2008 | 12:17 PM
Baaaaabump
Old Nov 15, 2008 | 05:49 PM
DODGER BOMBER's Avatar
I also have the smae problem with my 03. Light has been on f over 100,xxxkm. they said the module was NG. But i dont have time to replace the dang thing.
fitzydog
21
Oct 11, 2017 12:09 PM
dieselluvr
Dec 29, 2013 11:02 PM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
jahluvdiesel
Dec 26, 2002 01:15 AM
