315'S (HOW MANY REV'S)
Old Nov 15, 2003 | 10:43 PM
RACER47's Avatar
Anyone know what to tell the tech. at the dealer so he can calibrate my speedo with the 315/70/17's i just put on?
Old Nov 16, 2003 | 12:36 AM
Muzzy's Avatar
Re:315'S (HOW MANY REV'S)
BF Goodrich specs for the 315/70R17 show it at 601 Revs/mile @45mph.
-Muzzy
Old Nov 16, 2003 | 09:53 AM
gadgets's Avatar
The number I used was 600, just to keep it even; my gps says the truck thinks I'm going about 3/10th of a mile further each 35 miles, or so...
Otherwise, something around this figure should work.
Don't forget, averaging higher speeds will make for a larger diameter (I think), & that will introduce some error.
Also, as the tires wear down, the diameter will shrink somewhat.
I'm just going to leave the number where it is for now, & see how it plays out over some time..
Rene
Old Nov 17, 2003 | 09:05 AM
BamBam's Avatar
???I did not know they could recalibrate the speedo on these trucks??? Explain...please ???
Old Nov 17, 2003 | 10:05 AM
Crabjoe's Avatar
The dealer can recalibrate the speedo with their DBR III or whatever they computer is called by correcting the number of revolutions for a given tire size.
Old Nov 17, 2003 | 08:47 PM
gadgets's Avatar
BamBam:
Here's the quote:
"Just got back from a friend's who has the Dodge DRB 3 tool.
He hooked up the thing to the diagnostic port under the dash, scrolled down to the section on the ABS system, selected 'revs per mile'; I told him to plug in 600 (the range on the screen allowed anything between 400 - 900!!)"
On the ABS menu -
Choice 1 is 235(?) tires
Choice 2 is 265
Choice 3 is "Other"
Pick that, & then you can get 'revs per mile'.
Hope this helps.
Rene
Old Nov 17, 2003 | 09:14 PM
4x4's Avatar
4x4
Find an aftermarket calibrator, the one I use has a feature to switch between two settings for two different sets of tires. It mounts under the dash.
4x4
P.S. Hopes this helps.
Old Nov 18, 2003 | 10:32 AM
Crabjoe's Avatar
Anyone know the correct # of revs with 4.10 gears?
TIA
Old Nov 18, 2003 | 11:11 AM
bulabula's Avatar
tire revs are tire revs, no matter what gears you got.
Driveshaft revs/mile may vary, but not tire revs.
Old Nov 19, 2003 | 10:44 PM
Crabjoe's Avatar
Bulabula,
Your right! I don't know what I was thinking... Sometimes I just have to laugh at myself!!
Old Nov 30, 2003 | 07:58 PM
03CumminZ4X4's Avatar
It's 606 exactly. I figured the loaded rollout for the 315's and thats it. Service tech recalibrated mine and I checked it with my gps and its dead on at any speed. Hope this helps!! ;D
Old Nov 30, 2003 | 08:44 PM
RACER47's Avatar
What exactly do i tell the tech to do? Or will he know.
Old Nov 30, 2003 | 09:12 PM
Patrick Campbell's Avatar
How much are you guys paying for the Dodge ******* to do this?
I am thinking hard about putting on some 225/70/19.5's on my truck.
I'm picking the shortest 225/70/19.5 I can find which is about 652 revs per mile. I should not need any sort of lift right? Looks like 265/70/17 LTX A/S is 657 per mile so I am just a tiny bit bigger than them.
Old Dec 1, 2003 | 12:10 AM
Matt400's Avatar
[quote author=RACER47 link=board=17;threadid=22481;start=0#msg210096 date=1068957804]
[/quote]Give him the number he needs for your tire. He needs the revolution per mile. You should call the manufacture and get that number because no 2 tire molds are the same.
It would simply be a coincidence if a 315/70 BFG had the same RPM that a 317/70 Toyo had.
Old Dec 6, 2003 | 08:16 PM
Bighammer's Avatar
I asked at the dealer here in Traverse and they said it would be one hour service time ($70) so I walked out. > Maybe if I ever end up HAVING to take it in there, I might have them do it.
