2500 conversion
Old Sep 10, 2007 | 08:31 AM
Farmer Davis's Avatar
2500 conversion
I would like to convert my 2500 dodge into a 3500. What changes would I have to make to the truck to make it a real 1 ton? Hopefully someone knows what the differences are. Thanks
Old Sep 10, 2007 | 09:05 AM
bdewey's Avatar
I think the only real difference between the two is the extra helper spring in the back nad the 4.10 ratio in the rear end. Not to much different between the two.
Old Sep 10, 2007 | 10:09 AM
2003Ram's Avatar
The rear springs and badges. You could add clearance lights on the cab as well.
I was going to add factory overloads (I got 'em from Pauly) but the factory set-up has the spring contact perch welded to the frame on the 3500s. So, Hellwig overloads are the best bet for ease of installation.
Old Sep 10, 2007 | 01:44 PM
I got clearance lights and a 4.10 rear. So all I need to due is add an extra rear spring and perch along with badges. Is that right?
Old Sep 10, 2007 | 01:50 PM
2003Ram's Avatar
That is correct.
Old Sep 10, 2007 | 04:16 PM
05mxdiesel's Avatar
Hey Mr. Davis, just add a set of air bags which you can add air to as the weight increases and you get to keep your softer ride when unloaded. Probably cheaper or the same amount as adding overload springs and you have adjustability with bags.
Old Sep 10, 2007 | 04:38 PM
Raspy's Avatar
If you are doing it for legal load limit reasons you'll have to get it re-rated somehow. If you just want heavier rear springs (which is the real difference between the two) you can just get a set of overloads and, presto, instant one ton.
Forget the badges and the clearance lights. They do nothing for load carrying capacity. Oops, do you want a dually? Now that's a different story.
John
ram755
17
Dec 2, 2022 07:28 AM
Moparmatty
Cummins Conversions
Sep 9, 2009 12:35 PM
SOhappy
Jul 11, 2006 06:35 PM
Dieselhead
May 13, 2003 03:50 PM
DodgeBob
Jan 10, 2003 03:07 PM
