2013+ 18" wheels on a 2005
Old Sep 16, 2014 | 09:52 PM
bakerroc's Avatar
I was told that 18" wheels from 2013+ Rams will fit my 2005 to replace my 17" stock wheels. Does it matter if they come off a 4x4 or 2x4?
Rocky
Old Sep 17, 2014 | 04:25 AM
Nsomniac05's Avatar
Any 2500 or 3500 from 1994 to present will have an 8x165.1 bolt pattern with approx. 122mm center bore. 4wd or 2wd will not matter for wheel fitment, however, the cosmetic cover for the lugs and hub may be different from 4wd to 2wd.
Old Sep 17, 2014 | 09:15 AM
Danderson's Avatar
They have more bs and may rub the control arms with 285 tires.
Old Oct 15, 2014 | 04:54 AM
jdinny's Avatar
I was going to do the same thing with my '08.
The 18's have a +57mm offset and I didn't want the rubbing issue so I went for a set of 17's from a early '14 Laramie.
The 20's have a +54mm offset.
Old Oct 15, 2014 | 03:19 PM
NISMOramAE86's Avatar
I've contimplated the weight gain/loss when +1ing wheels and tires.
Opinion of looks aside, rotating mass of the unsprung weight has a preety big affect on performance (accel handling and braking). Yes, alot more so in a tiny 100HP 4 banger, but weight is weight and MPG is directly correlated with the amount of weight that needs to be moved.
Some rubber is alot heavier than others so what do you all think of.. or KNOW is heavier, the amount of metal added to the wheel when going bigger, or having a smaller wheel with a taller (more rubber) tire.
Old Oct 27, 2014 | 04:14 AM
Dodgezilla's Avatar
I am currently running a set of 18" rims/tires from a 2014 Laramie and the fit is great with the stock 275 tires. I can tell you that for sure. It doesn't look to me like putting 285s on these rims would cause any rub.
roughstock
Nov 2, 2013 01:48 PM
zeeew
Feb 2, 2011 08:19 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
