2006 Headlight Removal?
What is the trick of removing the headlight on an 06? I thought it was just removing the two bolts on the inside and pull it to the front? Tried that and it will only wiggle a little but will not move forward. Any tricks?
How I do it...
They are in there pretty good!
Use extreme caution as to not bend the sheet metal...
Stick something small and flat in between the light and fender, just enough to pop it out...doesn't take much to get it to move or to bend the metal, tho!
A rag covering the metal is a good idea, also.
MADHAT,
I will try to get the FCA out today and put yours in. I changed all 3 fuel filters yesterday and no change to the erratic rail pressure. I will let you know.
Man I'm glad I'm not the only one that this happened to. The back of the bumper must be a black hole because I could not find it. The funny thing is I got another nut from my stash and did the same thing.
There must be about 5 lbs of lost fasteners and tools all over my truck.
On my 06 I took the nut out from the wheel well and the 2 from the front, and then you have to pull it is tight, when I put it back in I just used the 2 in the front and left the nut off in the wheel well, they have been like this for a couple of years no problem, it is such a tight fit, seems fine.
mtdoragary
Nov 7, 2013 08:31 AM
Flashman
Feb 21, 2006 10:11 PM
jlipskoc
Oct 24, 2005 01:16 PM
