2005 intermitant wipers acting up
Old Nov 27, 2010 | 11:43 AM
nelly's Avatar
My 2005 intermitant wipers are acting all goofy, they will sweep 3-8 times in a row on the slowest setting...or they will work ok for a minute & then bugger up again...only on the intermitant settings.
Is It the switch or the relay?
Thanks,
Doug
Old Nov 27, 2010 | 11:10 PM
RDM16CTD's Avatar
X2 - my 05 is doing the same thing. Took it to the dealer but it started behaving again so all the diagnostics checked ok. Been going on for the last 6 months. So far it always seems to work the way it's supposed to if I put it on 'full' speed - but intermittent works the way Doug describes.
Old Nov 28, 2010 | 01:16 AM
nelly's Avatar
Im thinking of changing the relay (its only $20) & see what happens.
Old Dec 15, 2010 | 08:01 PM
thejoker502's Avatar
Nelly - Did that work? Mine will turn on very slowly then start to speed up. Some times they don't start at all but if I pull on them a bit they will start to work. Did the relay fix your issues?
Old Jan 18, 2011 | 12:25 AM
CanuckRam's Avatar
I have the same problem sometimes. Exactly as described here, then wipers will just randomly cycle without me touching the switch. Did changing the relay help?
Old Jan 18, 2011 | 07:32 AM
elirandolph's Avatar
Mine has been doing the same thing for a while now and I have never found a fix short of replacing the motor.
Old Jan 18, 2011 | 12:05 PM
Redtech1's Avatar
Same problem for over a year.
jgiachino
Feb 16, 2006 02:50 AM
Winr
17
Jul 21, 2004 08:15 PM
slam
Jul 28, 2003 07:09 PM
doomgaze
May 7, 2003 08:56 PM
