04.5 3500 Dually - GVWR and GVAR
Old Mar 30, 2009 | 04:16 PM
NDanecker's Avatar
04.5 3500 Dually - GVWR and GAWR
What is the GVWR and GAWR (front and rear) of a 04.5 Dually Quad Cab with 8 foot bed????
If anyone has one would they be kind enough to post.
Thanks!
Old Mar 31, 2009 | 04:23 AM
TexasCTD's Avatar
The GVWR (weight of truck and it's cargo) is 12,200lbs on a 3500 Dually due to the extra capacity of the rear tires. It's 9000lbs on a 2500 and 9900lbs on a Single rear wheel 3500. The spring packs are the same, but the 3500 models have 2 extra overload springs. Axles are the same.
Im sorry, I don't know the axle ratings off the top of my head. Hopefully somebody will chime in. I do know that they are very heavy duty and you will probably run out of tire capacity before you will run out of axle capacity, front or rear.
The GCVWR (weight of truck and it's cargo and trailer and it's cargo) towing is the same for all 04.5 trucks. 21,000lbs with 3.73 gears and 23,000lbs with 4.10s. That is the rating from Dodge, but our trucks can (and do) comfortably tow alot more.
Old Mar 31, 2009 | 08:37 PM
TonyB's Avatar
Axle weight rating should be on the federally mandated door sticker.
Tony
Tree DR
Dec 1, 2008 07:14 PM
rkinz
Jun 15, 2007 03:17 PM
Patrick Campbell
Mar 6, 2006 08:21 PM
nmcowboy
May 25, 2005 08:16 AM
KATOOM
21
Jul 9, 2003 05:37 PM
