3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Whats stock after DPF delete
Old Mar 16, 2011 | 08:25 AM
Timberwolf2's Avatar
Originally Posted by Scotty
I have been running SW 3 and defaults all on 1 except for the vgt...on 2 with the regular Smarty. I tried SW 5 and it sounded terrible. Idle was nasty and chatter on the top end was just too much for me. SW 7 was not as clattery but it shortened the life of the duals. Back to SW 3 for me. Maybe its a bit different on the junior?
JR only has 4 switches.
Old Mar 16, 2011 | 08:31 AM
ranchertx's Avatar
So, Smarty warns you not to take it to the dealer with the tune installed because if they flash it it will lock the tuner.
So, what do you guys do when you take your deleted truck in for service? Say the AC goes out, or power windos?
Old Mar 16, 2011 | 08:38 AM
jdinny's Avatar
You need to hook your Smarty back up and set it back to stock. This will unlock Smarty from your truck, and enable the dealer to do whatever they have to do.
Old Mar 16, 2011 | 04:07 PM
Dale M's Avatar
Well it kinda sounds like from Blake that you cant switch it
back to stock without putting all the delete stuff you took off back on the truck.. Putting the pipe and crap back on will be a pain in the ***.
You will error codes flashing all over with everything taken off and
no smarty installed to disable those.
Is that correct Blake?
Thanks
Dale M
Old Mar 16, 2011 | 06:39 PM
jdinny's Avatar
Yes, I believe you are correct. if you had to go in for warranty, you'd need to "undelete"
Old Mar 17, 2011 | 11:22 AM
ranchertx's Avatar
Too bad o no one makes a lock you can put on your ECM port so the dealer can't flash it W/O your permission? If I take it in for AC work or something not related to the engine they don't need to access it.
I guess what you guys are saying is once you delete, the truck never goes in to the dealer for anything? No way to return it to stock without replacing the Regen stuff I pulled off.
Old Mar 17, 2011 | 11:25 AM
jdinny's Avatar
Thats pretty much it.
I've got 50k left of warranty so I just took off the egr cross tube and plugged it. Same underneath, removed dpf and nox can and replaced with a delete pipe. Probably take 2 hours to get it back to stock.
Old Mar 17, 2011 | 02:54 PM
mega-engr's Avatar
"California Style"
That's been my plan for the past 2 years since I did these simplest of deletes... With the low miles I have, my warantee is on time not miles... Longest time period I think is 5 years for warantee?
Old Mar 18, 2011 | 09:18 AM
jdinny's Avatar
mega-engr,
What tune and settings do you run your Smarty at? Last nite,I set mine @ Catcher #3, timing @3, and VGT @3. Is it safe to leave it like that? I don't ever beat the truck hard, just get on it once and awhile.
Old Mar 18, 2011 | 03:01 PM
mega-engr's Avatar
"California Style"
mega-engr,
I run SW3 at the stock REVO setting for the Smarty Sr. I wish I had more time to play around with it and make some changes to them. I think you'd be fine with your settings especially if you are paying attention to how you are driving/using it.
I'd like to stick in SW9 and get the POD (power on demand) set up right actually myself...
Old Mar 18, 2011 | 03:25 PM
jdinny's Avatar
I really don't ever hammer on it, I just wondered if the timing setting would be ok. Seems to me in the manual it say for aftermarket injectors. I think I'll cut it back to #2. it does run awesome though.
I haven't even tried the POD stuff yet.
Old Mar 18, 2011 | 03:53 PM
Lil Dog's Avatar
I would shy away from the advanced timing settings. I have been doing some reading and it may cause a little more harm than good over the advance that the S-67 already puts in.
I haven't tried the POD either. SW5 Tq2 Tim 2 RP2 VGT2
Old Mar 18, 2011 | 04:05 PM
jdinny's Avatar
Lil Dog, you're running the Smarty @ SW5 with no other adjustments?
Old Mar 18, 2011 | 10:43 PM
Navy7797's Avatar
Settings
Originally Posted by AH64ID
Correct. SW1 doesn't add any fuel over the stock tables, it just bumps the timing up.
Timing on the HPCR's is retarded from the factory to meet emissions, so its optimal for emissions and not power/economy.
I haven't seen a dyno chart for the 6.7, but on the 5.9 the timing makes the biggest differene in the mid range, 1400-2600.
AH64ID: AT SW1 40 hp you get better mileage than the "stock" setting?
I'm been running Stock setting and POD at 80% , this gave me 3-4 mpg more than before the deletes. Will I get even better with mpg with SW1 ? Thanks for the input.
Old Mar 19, 2011 | 08:36 AM
AH64ID's Avatar
Yes timing helps mileage/power/etc. Consider on my 5.9 Jr I made up to about 80-90 ft/lbs of more tq from 1600-2400 on timing only, thats free power!
