3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
What size rims and tires?
Old Jan 19, 2013 | 06:28 PM
'0825004x4's Avatar
Just bought a used '08 2500 4x4. Am planning on doing the two inch leveling kit. My question is what are the biggest tires I can run without rubbing and what size rim should I go with. Was looking at the 18" rim, but it looks like I have alot more selection by going with the stock size rim of 17". Would like to run the biggest BFG A/T I can. Also plan on doing the DPF delete and have already purchased the XRT-pro Programmer. Was told they are no longer going to be selling these because of EPA. Any info on both would be appreciated. Thanks in advance.
Old Jan 19, 2013 | 10:18 PM
Rednecktastic's Avatar
9 inch wide wheel with no less than 5.5 backspacking.
315/70/17 is bfg tire you are looking for. It is ok, I've ran it. It is D rated and I swapped to an E rated tire; even though that 315 is rated for the same weight as the factory tire seems I had to keep the fronts aired almost to max to keep them from sagging.
Old Jan 20, 2013 | 05:30 PM
'0825004x4's Avatar
Thanks Rednecktastic. Which e-rated tire did you go with?
Old Jan 27, 2013 | 11:59 AM
i've had hankook m/t and nitto trail grapplers in 35x12.50
19mike92
Apr 4, 2013 07:59 PM
1320
May 29, 2009 10:24 PM
flyright
Oct 16, 2007 08:20 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
