3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Studded Head.....?????
Old Jun 12, 2010 | 01:17 PM
Bluetek's Avatar
Please explain "Studded Head". Do you have to replace all the stud bolts on the head?? Sorry to be so mentally challanged
Old Jun 12, 2010 | 01:36 PM
got_soot's Avatar
Soot For Brains!
http://www.thoroughbreddiesel.com/ar...studs.htm(pics. of studs)
When you have a studded head, you replace the oem bolts with studs(usually arps) that can handle alot more pressure without stretching or breaking, so you can up the boost or add nos..ect... without blowing headgaskets ect.. and yes you replace all bolts that fasten the head down with the studs...
Old Jun 12, 2010 | 05:56 PM
Bluetek's Avatar
Thanks G.S. for the info. I did a lot of research before I deleted and installed smarty jr, thinking that the jr. would not exceed any limits or cause damage.
Old Jun 12, 2010 | 06:52 PM
got_soot's Avatar
Soot For Brains!
No prob. buddy,your fine if your running the jr.. if you go bigger, like boost over 45psi or big set of injectors ect... thats when id stud it..
Old Jun 12, 2010 | 09:12 PM
Bluetek's Avatar
Thanks again. I pull a 5th wheel with a bass boat or ATV trailer behind it. i wanted a little more power, but mostly better fuel mileage and jr. seems to be doing that for me. Some of the threads on other forums are not so positive and i begin second guessing myself. Your info is appreciated.
Old Jun 13, 2010 | 02:19 PM
got_soot's Avatar
Soot For Brains!
Yeah other forums are known to be like that, so thats why i am here along with others that feel the same way. If you have any other questions just feel free to private message me and i will do my best to answer them..
Old Jun 13, 2010 | 03:40 PM
Blake Clark's Avatar
I concur with Sooty
Unless you running hard (specially when cold), lots of timing, high boost, and high HP tunes you should be ok.
98rambaby
Apr 2, 2013 10:14 PM
captntim
20
Aug 15, 2009 04:53 PM
dieselman2300
Nov 24, 2007 09:29 PM
Nimrod
15
Dec 14, 2003 01:06 PM
