3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Smarty Jr Question
Old Aug 15, 2013 | 03:51 PM
Blackie49's Avatar
Thank you XCC_Rider for your help solving this issue , it sure makes it great when there are people like you who take the time to help others ... Again thanks to all who have helped. Brett
Old Aug 15, 2013 | 04:13 PM
ColinP's Avatar
awesome information here!
Old Nov 11, 2013 | 09:50 PM
Blackie49's Avatar
Thumbs up
Thought I would update this post to help others
I had to update my smarty to the EPA compliant tunes and also needed a PC based computer to do it so I picked up a used laptop and downloaded the software and installed it to the smarty jr .
I have been using the truck for over a week now with no issues thanks again...
Old Nov 11, 2013 | 11:36 PM
xcc_rider's Avatar
Glad to help
Old Dec 1, 2013 | 03:36 PM
Blackie49's Avatar
Now have code po40b ?
Any help with how to get rid of this other than delete the codes with the smarty?
Old Dec 1, 2013 | 09:44 PM
xcc_rider's Avatar
P-040b-Exhaust Gas Recirculation Temperature Sensor 1 Circuit Performance
Are you still stock or did you delete already?
If stock is it the DRS01L tune. If not then try loading that tune.
Sounds like this is a code for a C&C or sprinter, not one of our style trucks.
For a C&C or Sprinter the causes are listed as a plugged egr cooler, plugged or sticking egr valve.
Old Dec 1, 2013 | 10:05 PM
Blackie49's Avatar
I am still stock under extended warrantee the drso1L tune is what I loaded the smarty with unless I have to update it ?
I will look into this Monday and download the DRso1lL tune thanks for help again
Old Dec 1, 2013 | 10:29 PM
Blackie49's Avatar
Side note I went out and used the smarty to erase the codes and set it back to stock tune for now, I will reload the smarty Monday !
Old Dec 2, 2013 | 05:34 PM
Blackie49's Avatar
Drove 30 miles today got home and no codes? No engine light? Guess I will just wait ! Could this be a cold weather thing?
I have the DRSO1L tune loaded?
Old Dec 2, 2013 | 08:59 PM
xcc_rider's Avatar
Drive a while with the stock tune. If the code comes back in then its not tune related. Reload the smarty tune and see if it come back. If not then it was just an anomaly, if so then its most likely tune related and you need to give mads a call.
How many miles do you have on the truck. There's a 67,500 egr system cleaning and ccv filter replacement due at that mileage. If you're past it then its possible the egr cooler is fouled and/or the egr valve is sticking or stricted causing the code.
Geno's has a cleaning kit with the ccv filter for something like $130 and comes with the instructions to do so. A lot cheaper than dodges $450(?) to do the service.
Old Dec 3, 2013 | 06:01 PM
Blackie49's Avatar
Mileage is 86,000 Kms 53000 miles so I will keep that in mind about the service and get the kit from Gino's garage.
Second day driving around 30 miles and no engine light , so hope and wait, thanks for helping me , I really appreciate you help on this , great feed back on things to look at.
thank you. XCC Rider
Old Dec 11, 2013 | 10:13 PM
Blackie49's Avatar
Still all good no lights , so must be a fault with the tune
Old Dec 12, 2013 | 12:11 AM
xcc_rider's Avatar
Tune related, Hmmmm, interesting!
I re read the entire topic again and saw where you asked if the code could be weather related.
I want to say yes, if you're in an extremely cold area but I really don't know since I don't have experience with the compliant tunes. Cold weather and egr temperature seems to go together but im lost on this one. Plus youre not getting the code now so i think youre right.
Usually in cold climates you'll get a cooling system/thermostat rationalization code and I haven't heard of this one coming in.
If you would, please join the smartyresource.net forum and post a question re the code, the epa tune you had loaded and your finding that it looks tune related. Include a link to this topic for them to read for more background. Brian from smarty will reply and may be able to give you more info and perhaps send you an older epa tune to try instead of the DRS01L tune. (Someimes new tunes have kinks in them and they need to know about them to get them ironed out).
thx, dan
Old Dec 15, 2013 | 10:28 AM
xcc_rider's Avatar
Have you tried reloading the L tune yet? It would be interesting to see if the codes come back with it loaded.
If they do then return it to stock and try the older tune on the page below. Its the BR24S epa tune. You'll need to download it and unzip it using 7zip before loading on the tuner.
http://wayback.archive.org/web/20120...wnloadJ67.html
Let us know what happens.
Old Dec 15, 2013 | 06:36 PM
moparguy62's Avatar
Originally Posted by Blackie49
the thing i need to know is do the deletes have to be done .... or can you run the smarty catcher towing setting on a stock truck?
Blacky this may be to late or an old post, you can run a tuner without deletes, but it will regen more as you will produce more soot running tunes.
