Mud flaps to go with fender flares?
I have a 2007 ram 2500 purchased last year. The previous owner installed some wider aftermarket rims and tires but no fender flares, which made driving on anything but dry hard surfaces very messy. I installed some Bushwhacker fender flares which helped quite a bit but there is still considerable mud/dirt/etc spraying the sides and some rock chips happening along the front rocker panel areas. Can anyone suggest some good mud flaps that are compatible with the Bushwacker fender flares?
Thanks!
-Roy
Thanks!
-Roy
check out Dura Flaps. I haven't used them myself, but a lot of great reviews and they do custom sizes. Likely they've dealt with the flares before!
http://www.duraflap.com/
x2 for duraflap, have had 2 sets for 2 different trucks and have been extremely happy with the quality and the support i received from duraflap.
if you need them a little larger they will work with you, that way you can trim them to size on your own.
cowboy1814
11-15-2008 06:38 PM
dodchall70
02-23-2007 07:21 PM
Uncle Red
0
07-18-2005 09:50 AM
