3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Lost all power, overhead read catilist full need service
Old Nov 22, 2012 | 07:33 PM
Rob Mitch's Avatar
Had a problem yesterday. I had driven 200 miles and into the Hill Country pulling a 7k rv and all the sudden I heard a "ding" and then lost most power. Overhead read catilist full need service, I had to pull over and stop. I cut key off and it was hard to start but when it did power was normal. this happened every couple of miles and I checked for codes and it read P0489 Did this evwery couple miles till I got to destination about twenty miles. most of the times I hooked up mu Smarty S67ME to clear code and it was clear. Truck actually died a couple of times while I was still rolling. This morning I checked for code and didn"t find any. Truck started normal and seemed to run good for ten miles although without trailer. I have done full deletes on this 2007 6.7 and have been using SW3 on my smarty. Can any one give me any idea what's going on. I am wondering if this thing will get me home.
Robert
Old Nov 23, 2012 | 07:20 AM
Rob Mitch's Avatar
Forgot to mention I still have the original programing in my Smarty, I haven't updated it to the 28 yet.
Robert
Old Nov 23, 2012 | 12:18 PM
RamGazer's Avatar
10 Year Member
Good Luck.
Old Nov 23, 2012 | 04:31 PM
Racerchaser's Avatar
I don't think it would be the EGR.......his sig says he already got rid of that!
Old Nov 23, 2012 | 06:24 PM
Rob Mitch's Avatar
Yes I've done aLL of the deletes. Today I reinstalled sw3 with my smarty and it didn't do it. I'm hoping for the best. The overhead does ding and say "catilist full service required" when this happens.
Old Nov 25, 2012 | 02:54 PM
Rob Mitch's Avatar
Ran great the first 175 miles today pulling my trailer, the last 75 miles was holy heck. Barely pulled the last couple of slight hills in 3rd or 4tth gear. My nerves are shot wondering if I was going to make it at all, and I'm ready to stick a match to it/.
Old Nov 26, 2012 | 01:04 PM
Circle B's Avatar
Robert, before you torch it you may want to PM Blake Clark. He had a 2008 running a smarty before getting his latest ride and had the "Catalyst Full See Dealer Now" issue. I run an H&S Mini Max on my 08 so cannot speak from experience; however, based on what I could find in older posts, MADS has had updates from version 20me and up that addressed the issue. You may need to find and download a newer file for your smarty (Blake has those files).
One other thing to check is the 2 pressure sensor ports on the side of the tranny. Do you have them looped (or plugged) or are they open and able to 'breath'? I have read and heard that these ports should remain open, plugging or looping them may cause issues.
Just some thoughts....JB
Old Nov 26, 2012 | 05:53 PM
xcc_rider's Avatar
X2
time to update!
Old Nov 26, 2012 | 08:21 PM
Rob Mitch's Avatar
Circle B, Thanks for the reply. That helps me a lot to know that the smarty update may fix this. I got the latest update from Blake last week but have been going so much I haven't had time to install it into my Smarty. Also I'm not sure I'm computer savy enough to even do that : ( Is that very difficult? Seems like I read something about those pressure ports. Does that apply to the standard trans? I'll check the delete thread then check the truck tomorrow. Today, without the trailer it runs real strong. Of course I only ran it mabey ten miles. I'll PM Blake too and maybe he will have some more ideas. Thanks again for the help I was really disgusted with it yesterday. It started this the other side of Marble Falls. I see your from Central Texas too. I'm from Temple Maybe I can buy you a cup of coffee sometime.
Old Nov 26, 2012 | 08:24 PM
Rob Mitch's Avatar
Originally Posted by xcc_rider
X2
time to update!
Thanks xcc_rider for replying. I was sure worried at first but starting to feel better about it now.
Old Nov 27, 2012 | 01:11 PM
xcc_rider's Avatar
Well, don't start feeling better yet. You said you were'nt computer savy so you've got alot of reading to do. Or consider it alittle review...
1st, go here and select your programmer from the pictures. It will take you to the download section. You don't want to download a tune, just the info in the documentation section. http://www.madselectronics.com/download.html
Next go here and read about all the quirks and such you'll find when installing a tune. Alot of good info here: http://www.cumminsforum.com/forum/07...formation.html
And here: http://www.cumminsforum.com/forum/6-...ok-inside.html
And now you're ready...
good luck, dan
Old Nov 27, 2012 | 08:17 PM
Rob Mitch's Avatar
I feel better now, I got a computer savy friend to update my Smarty for me. I'll get the truck done in the morning. Maybe this weekend I can hook up and run it enough to find out if this does the trick. %#*% the epa that causes all this $$#*
Old Nov 29, 2012 | 08:03 PM
robby t's Avatar
hey rob keep us posted.....i have the same truck that is strange.......
Old Nov 30, 2012 | 07:05 AM
Rob Mitch's Avatar
I may know today if it works right. I'm pulling the trailer a couple hundred miles today. I won't have internet access till next Tuesday though. I'll let you know by then. I did check the sensor on the side of the trans yesterday. I had put a hose joining the two ports. That should keep pressure equal on both sides. That should be good I think but if it happens again I'll just vent both sides to atmosphere (cut the hose) and see if there is a difference.
Rob
Old Nov 30, 2012 | 11:03 PM
robby t's Avatar
hey rob.....I have my sensor plugged on both sides no problems for 40k...good luck let me know...
