G-56 & Hp/tq
Probably depends on what gear you are in when you hammer it. I have the Dr. Performance Stage III 110/220 module, but never hammer it in 6th, and only really hammered it in 5th once. Seems like if you just get on it hard in 2-4th there is less load on the clutch. That's my theory anyway.
Not that I would try to sled pull or drag race on a stock clutch anyway...
Smaty jr on 3 will slip at will. Holds two pretty good. Set on 3 at 80% pod dosent slip but something is getting bound up because once in a while i cant push the clutch in.Like the throw out bearing is binding. It's going in tomorrow for a new clutch. Will post new thread on the results.
