3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
6.7 Pyro Install...
Old 07-09-2009, 09:54 PM
BroncoHound's Avatar
Here's where I put mine:
Old 07-09-2009, 09:57 PM
Lil Dog's Avatar
Mines about an inch up and ahead of that, just in behind the elbow for the CCV. Thanks Bronco..
Old 07-09-2009, 10:14 PM
The Guru
Mike Holmen's Avatar
Did you guys remove the turbo or just drilled the hole with the turbo still attached to the exhaust manifold?
Old 07-09-2009, 10:26 PM
Left everything attached here.
Old 07-10-2009, 11:25 AM
Lil Dog's Avatar
Just drilled through. No pilot hole deeper than 1/16"
Old 07-11-2009, 07:13 PM
The Guru
I've been phoning around but I can't find any one that can build a "race" transmission for the RE68
I was thinking about running some power, one day with this 09 quad one day. Once I put a dent in it.
Dog, has your truck done a regen cycle since the smarty adjustment?
Old 03-11-2011, 09:58 AM
Dale M's Avatar
Hi. Isnt there a risk of all the cuttings getting into the turdo from drilling and tapping this hole? I need to do this too and worried about messing up the turbo.
Thanks
Dale M
Thanks
Old 03-11-2011, 10:41 AM
Thanks
Dale M
Thanks
Just go slow, put a dab of moly grease on the tip of the drill bit to catch the shavings, and clean and reapply often.
Old 03-11-2011, 04:30 PM
"California Style"
mega-engr's Avatar
Thanks
Dale M
Thanks
There is always a risk for such things, but think it is pretty low. I have not heard of anyone having an issue with their turbo no matter how they chose to do the drilling. I used grease and kept the motor running to provide some positive pressure inside to help keep any chips from going in... You'll be just fine.
Old 03-30-2011, 09:54 AM
Grand Geek's Avatar
Thanks
Dale M
Thanks
Well i'm glad its not just me worried bout this.. My gauges for my 04 that i bought new are still in my tool box.. i havent even thought of buying any for the 2011 since i wont drill em on the old one.. I dont work em that hard..
Old 03-30-2011, 10:20 AM
Lil Dog's Avatar
The drilling and tapping is not as bad as it sounds. Its a cast manifold so the chips are usually pretty small and light with 98% of them coming out of the hole before you punch through. Using some lube on the drill to retain the chips and make a clean cut is the key to keeping them from falling in near the end. Patience.
On the stock truck, the pyro makes a good DPF REGEN indicator so you can make sure the process is done before you park it in the dry grass.
lovemysan
01-12-2005 05:19 PM
Buzz
14
03-25-2004 11:12 AM
CTD99
05-19-2003 10:24 AM
redram
12-10-2002 09:54 AM
bdog
11-05-2002 02:09 AM
Quick Reply: 6.7 Pyro Install...
