5.9 head on a 6.7
I actually think that it would work. Dont quote me on that though. Maybe lil dog will chime in, he may know.
I am not sure it would work that way with your electronics...
But a 5.9 head will work on a 6.7 block, with 5.9 electronics and ECM... There is a local guy with one, I guess the extra displacement spools the turbo pretty quick compared to a similar 5.9.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
yes it will work. ultimate sleeper. a stock 6.7 will spool a silver 66 turbo very nicely with the extra displacement. I am in the hunt for one myself.
You could also put a 6.7 rail pressure sensor in and run a little more pressure with stock programing, since the 6.7 injectors are designed for more pressure.
But the main reason would be the increased displacement.
What all would be required for this. A new ECM, new manifold, etc???
Wonder if it would be worth it to go 5.9 head, studs, etc to go with twins vs the 6.7 twins setup from Rip Rook (or similar)
Im starting to think that for 600+ hp Id forgo the EB.
would have to run 5.9 injectors with nozzles to match the spray pattern for the 6.7
5.9 electronics. the only thing for the 6.7 you would run is the block itself. all others would be 5.9
i would rather use an aftermarket EB than that VGT. too many issues with the VGT and what would you do for electronics? Cheetah?
More or less considering doing away with the VGT all together with a compound setup.
Maybe easier to just leave the 6.7 head in place and swap for a good 5.9 manifold with twins.
Just curious, at what point does the 4" become too restrictive and the 5" needed for flow??
Zilla sorry for the hijack, but figured it was all kinda relevant for a big build....
