Your thoughts on my upgrades
Old Jun 2, 2008 | 08:49 PM
Dodge1Dodge's Avatar
First off, hello to everyone. This is my first post and I just purchased my first dodge: an '05 2500 4x4 Laramie, bone stock. I will be doing my first round of improvements soon. I am aiming primarily at gaining in mpg but hp and a different exhaust tone are nice two. Here is what I am planning so far:
Aero 5050xl
Quadzilla max mileage
True Flow XDI
maybe a CFM intake manifold if I can convince the wife
What do you think?
Old Jun 2, 2008 | 08:54 PM
powermad's Avatar
sounds good so far! i would do the cfm as well i noticed as big of a diferance with that as i did with intake and exhaust combined
Old Jun 2, 2008 | 09:09 PM
madhat's Avatar
Administrator/Jarhead
GUAGES!!! Looks good so far. Do the supporting mods first.
Welcome to the DTR!
What direction are you looking to go with your truck?
Old Jun 2, 2008 | 09:30 PM
jmccart's Avatar
Sounds like fun coming your way.
Old Jun 2, 2008 | 09:43 PM
matego's Avatar
madhat's monkey boy...
Isnt this the way we all started? Next thing you will have 600HP and be 10k lighter in the wallet. Personally I would skip the CFM and use that cash for gauges. At least pyro and boost. Fuel pressure is nice as well.
Old Jun 2, 2008 | 09:44 PM
omaharam's Avatar
Welcome,
Is the truck an auto or stick?
Also, if you do an intake manifold, you might re-consider the CFM for one of the following.
http://www.hellmannperformance.com/
http://www.glacierdieselpower.com/pr...pf_id=0307-PFI
Old Jun 2, 2008 | 09:45 PM
OutOfSight's Avatar
Skip the CFM...my stock intake horn is pushing over 700HP and 60PSI...
Old Jun 2, 2008 | 09:52 PM
powermad's Avatar
yea i missed the gauges not being in your sig, but in my eyes i noticed a big difference with the cfm, plus i heard a lot of bad about running water/meth with a metal intake well not a lot just that they rust out and i dont want to risk rust going though my engine! one thing i dont like about the cfm theirs only 3 holes for gauges and injectables. that is if you plan on ever running water/meth
Old Jun 2, 2008 | 11:07 PM
Hmmmm... intake horns, powerflow intake manifold. I can actually hear my wallet getting thinner (but my truck is getting better right!). I definitely will do gauges next, but maybe now swap those for the CFM. I have an auto so I know something will soon follow (read: fall off) for that department.
I am completely uneducated when it comes to water/meth, so that might be in round three.
Thanks for the responses guys.
Old Jun 3, 2008 | 06:24 AM
n2moto's Avatar
Add the steering box bearing brace. I don't know what the exact name is but I know somebody will help out.
Carli levelling kit. 33" rubber, calibrate speedo, Aftermarket lift pump, Better lighting, Gauges, Pac Brake, Air intake system.
Then shovel a bunch of cash into your transmission before you start putting the juice to your engine or you'll be backing a dump truck full of cash to the transmission shop after it goes south.
Well that's what I would do.
Old Jun 3, 2008 | 06:44 AM
Hintz's Avatar
Originally Posted by omaharam
Welcome,
I agree hellmann makes some trick stuff as does GDP
Old Jun 3, 2008 | 06:58 AM
tritont's Avatar
CFM probably wouldn't be a good idea with water/meth. There have been at least 3 I know of that were blown apart into pieces. IIRC, it wasn't at very high boost either. It is composite but, it is plastic. I think it's a great intake... just not for a truck with lots of power
I would agree to not bother with a intake and put the money elsewhere.
Old Jun 3, 2008 | 07:00 AM
OT-OF-Here's Avatar
Mods
IMO, your Aero is/was a waste of $$$. Don't feel bad,.. many others bit,.. including your truly. Also the 50/50 I believe indicates it is a 5" piece,..right? It's been dyno proven many times that you only need 5" above 500hp/550hp.
Next I'd get the gauges as others suggested. Keep in mind many of the boxes have monitors that include the gauges.
Old Jun 3, 2008 | 07:14 AM
tritont's Avatar
why was the Aero a waste ? I've had a 4040XL for well over a year now and it's done very well. I had a MBRP before that and IMO, the Aero, sounds better with less drone. I don't think a 5" exhaust is even necessary until after 1000hp if even then. I don't know if 5" downpipes are even made, most are 3.5 or 4" so how would it benefit to go 5" from there ?
Old Jun 3, 2008 | 07:17 AM
Hintz's Avatar
W/ exhaust honestly, Id get a sawzall and be done w/ it (save some $$$), IMO my straight exhaust sounds better than my buddies 5 inch system,
