You guys with Projector/ Halo head-lights???
-After having them on for a while, do you still like them???
-Is the light any better???.
-Did you have to splice wires???
-How is the second set of lights (high beams) hooked up (is it a plug set up or wire splicing)???
I really like the looks for them, and if they are just as good as factory lighting than I will get some. But I won't get them if they are worse than factory lighting...
Thanks in advance...
I had them,, they sucked,, I hated them from the moment I put them on, til the moment I took them off and threw them in the dumpster. The only thing I liked was how they looked
Kevin
Kevin
I had them, and they were ok. Light output was a little bit better. They looked pretty cool with the Halos lit up. Splicing is required for the turn signal led's and halo lighting. The headlights (regular and high beam) were just plug and play. I have pictures in my gallery. I took mine off due to the fact I am going to black out this truck entirely, so they would have stuck out too much. I still have the halo units, I would send them your way for $100 + shipping if you want to try them.
Thanks guys,
Good question, what kind of bulbs do they use (I wonder if you could get a little better wattage)??.. It would be great if they where H4's
These things are now selling on E-bay for $100 a pair (+ $45 in shipping
They use to be like $200 a pair but now they are alot less and I am getting to where I can start looking at them again.
I really like the looks of them, but I just won't compromise on light output, since the factory ones seem to be dim enough...
Are thier different makers of them or is it just one company?
Anyone else have any experience with these???
)... They use to be like $200 a pair but now they are alot less and I am getting to where I can start looking at them again.
hella makes a higher watage bulb
http://store.summitracing.com/partde...5&autoview=sku
for the stock 9007 lamp
FLMarine
0
Apr 30, 2014 09:10 PM
jdanruby
15
Nov 20, 2011 08:38 PM
GEN3TRQMONSTER
Jan 28, 2008 02:00 PM
artieb
Feb 11, 2007 09:26 AM
twvette
24
Nov 22, 2006 12:41 AM
