Would like to convert from 4x2 to 4x4
I bought a 4x2 truck that I really don't like because its a 2 wheel drive. I would like to convert to a 4x4. What parts do I need in order. Oh and would it be possible to put the new front assembly that come in the new 5500 models? Thanks.
like mentioned above, alot of work, but you would atleast need the front axle assembly (complete), front driveshaft, trans to transfer case adapter (may be easier to find a 4x4 tranny and sell yours), transfer case (manual shift would definately be the way to go), modify rear driveshaft. Different front springs? Maybe rear springs? Don't the 2wd trucks sit lower than the 4wd ones? Maybe different tranny crossmember if there is no allowance for a front driveshaft?
I've never looked under a 2wd truck, I wonder if the axle would be a bolt in affair? If so, the work wouldn't be too bad. Now if you have to do any cutting and welding on the frame to get brackets in the right spot, it would be a pain in the rear.
Also, steering components might need changed (pitman arm, draglink, etc)... If the front sits higher, maybe longer brake lines as well...
I had the same questions with my last truck. I wanted to throw a Dana 60 and leaf springs under it. I had access to an axle and a divorced NP205. One obstacle is I think the 2x4 had rack/pinion steering instead of a normal box (correct me if I am wrong). A guy who does IFS-straight axle conversions of Gm trucks told me I would really be better off and money ahead to sell & get a 4x4. The only way I see it making sense is if you can do all the work yourself. And if you are a kick-butt fabricator, I would not bother looking at the 5500 axle, just get a Dana 60 & a divorced NP205.
Good luck if you go for it, though!
Just kidding of course Banks just doesnt get a real good rap on here. To each his own.
