Will the HTB2 from the 03 fit the 07?
Old Oct 8, 2006 | 11:54 AM
Dodgezilla's Avatar
Is everything the same as far as the exhaust outlet side goes? I had a 4" downpipe on the 03 and I think this one looks about the same size but I just want to be sure before I rip this thing apart just to find out something is different....
Old Oct 8, 2006 | 12:16 PM
wap's Avatar
wap
As for as location I do not know but your new truck has a 4" dp, if that helps any.
Old Oct 8, 2006 | 01:01 PM
Dodgezilla's Avatar
That I am aware of. I'm really wondering if the elbow is still 4" on both ends. The part number is not the same as another 4" elbow I have here...
Old Oct 14, 2006 | 09:53 AM
Dodgezilla's Avatar
I guess nobody has the answer? I also guess the wastegate will work properly too???
I am thinking about putting this on today....
Old Oct 14, 2006 | 10:04 AM
Marine's Avatar
Veteran: Marine Corp
Might as well try it.
I have no idea, but I look forward to the answer!
Old Oct 14, 2006 | 10:13 AM
Dodgezilla's Avatar
Well, I really just hate to go through the hassle to find that something won't work and then have to put the stock one back on. I might do it anyways. I can just pull the stock elbow off and match it up with an extra one I already have. That's the easy part. The wastegate is the big question now....
Old Oct 14, 2006 | 10:16 AM
Marine's Avatar
Why would the wastegate be an issue? The location of it?
Old Oct 14, 2006 | 10:19 AM
masonic-dodge's Avatar
Your turbo will fit- The 07 is the same as an 06 til jan 07 the only thing is the elbow, but the 04.5-07 has a larger elbow so thats a good thing.
CRIS
Old Oct 14, 2006 | 10:20 AM
Dodgezilla's Avatar
I just don't know crap about turbos. I know I can't put a new turbo on an older truck because of the electronic wastegate. I don't know if it's the same for a mechanical one going on a truck with an electronic one....
Old Oct 14, 2006 | 10:24 AM
Put the turbo on your truck!!!!!! It will work. You just have to jump the 2 wires in your plug for your waste-gate.
CRIS
Dodgezilla's Avatar
Alright. Maybe I'll try to get this thing on after I pull the muffler off.....
I guess you mean connect the two wires together???
Old Oct 14, 2006 | 10:27 AM
Just remember like your 03 your are going to have to cut that little tit off your factory elbow. My turbo for my 05 came with a plug to plug into the wire that goes to the waste-gate, but all it does is jump the 2 wires.
CRIS
Old Oct 14, 2006 | 10:31 AM
Dodgezilla's Avatar
Actually I had a Banks Downpipe so I didn't have to worry about messing with the elbow. I assume you are referring to the pins that stick out to line it up with the stock turbo??
Old Oct 14, 2006 | 10:34 AM
Call me ASAP
CRIS
Old Oct 14, 2006 | 03:28 PM
Dodgezilla's Avatar
Cris, I have been calling your name out as loud as I can but I'm not getting any answer! I even got on the roof and called but nothing!!! I decided to just do the muffler today and maybe tomorrow I'll tackle the turbo. You said call but gave no number....
