View Poll Results: Straight piped????
Multiple Choice Poll. Voters: 176. You may not vote on this poll
Whos got em straight piped?
#31
Does anyone have a better picture of this seal clamp? So what you are saying is I could buy a piece of straight pipe cut the muffler out then when I want (if for example I am going on a long road trip) put it back on with these clamps? That would be sweet where can I get some pipe bent to work?
Good luck.
And your plan sounds like mine. I'll buy another set of rims and have a street set and a mud set of tires. Then I'll just switch them when it rains a lot. Ya, right. I'm too lazy!
#32
I actually meant, you could put them on, then if you didn't like it, you could take it off ONCE. The clamps do say on the box "DO NOT REUSE". Now, I switched turbos and clutches and had to take them off twice now, but they will not seal as good the second and third time around. They will stretch more everytime you use them. So, be carefull. If you take them on and off several times, the WILL losen up.
Good luck.
Good luck.
Taken mine off too many times to count, still clamps down just fine....
#34
If you want to make a butt splice, two OD's together, you must buy and OD to OD adapter and put a clamp on each end.
#35
I never had luck with butt splices like you said, with the clamp losing up, but also just not staying tight and allowing the pipe to move...
Flexpipe fits over the said size, so youd use that type of clamp for flex, or a flared aftermarket system, instead of the crush bend clamps that youll never seperate the pipe again
#36
u just gotta do it i cant see why to spend money on a mbrp or what ever when for about 40 bucks you can have a better sound and probly just as good a flow loose the cat and muff . straight is where its at!!!!!!!!!!!!! 05 dually volant cai,edge juice/atitude g56 6spd,373 loaded to the gills love it!
#37
just get an off brand 5"
#38
ok guys its my turn to ask another dumb question . i have a 04 305-555 2500 4x4 CTD truck.I was going to straight pipe my truck to day. but the guy i took it to .Said he could not do it. Because the pipe going into the muffler sits lower than the tail pipe. All i had with me was a 4 foot section of 3-1/2 pipe. so my dumb question is, how did all of you guys that straight piped your truck do it. Allso picks would be very helpfull.thanks for all the help and info guys. Bobby Miller
#39
Sounds like that muffler shop doesnt know what hes doing.
If I can do it at a buddys house, borrowing his welder and chop saw and sawzall, a muffler shop can do it easily...
Heres a pic of what im talking about...
#40
last night I turned down the radio, rolled down the windows and cranked the hotjuice up to 4 (dont like 5, need more fuel) and went to town down a quiet road. man it sounded mean, I never listen to my exhaust as I really love A/C but I figured I should since I like to pump the throttle in the neighborhood, no wonder peoples heads turn all the time. lol
#42
I personally would not spend $800 to $1000 on some fancy smancy exhaust system. I ran a 4" down pipe, into 5" all the way back to a 5" stack for around $350 to $400. Lose the stack and you'd save more. Just get on line at www.airflo.com and pick your parts. You also get the satisfaction of saying, "I built that myself", instead of "I had to buy it off the shelf because I have no imagination and it cost me an extra $600!
#45
straight piped
new to the cummins scene so want to get this right on my 03 4x4 quad shortbed, I need what? to straight pipe it????also going with a afe stage II and more than likely a triple dog what consideration for the down pipe?? TIA, Tony
