Where to buy Don M's Flux Injectors
Guest
Posts: n/a
Don M,
Are the injectors tested before and after for proper functioning or just afterwards? I am about to get my truck to Olee. I have had very low EGTs with this truck even with my boxes turned up and was hoping to find out if its an injector not flowing/funtioning properly. Thanks, George
joe,
I had a truck a few days back with some Flux nozzles make 77 HP over stock. Not too bad for a 40 HP injector. No TS performance events for me. Im busy and cant even make May Madness this year
Same dyno, same truck. Only an injector swap.
George,
If your injectors have running problems I like the idea of you getting some new ones from D/C. Tell me about the bnoxes you have on your truck. Type, power levels, etc.
What turbo??
Don~
Same dyno, same truck. Only an injector swap. George,
What turbo??
Don~
Guest
Posts: n/a
Don,
I have a Banks Six-Gun w/Speedloader, BDDL and PS2000 Propane, FASS, stock turbo. The only reason I think the injectors arent right is because of the low EGTs, the truck does run smootly but everyone has told me without the higher temps something must be wrong with fuel flow. It maybe that there is nothing wrong with them at all? Thanks, George
George, My guess is the injectors are fine. I almost suspect the fueling box.
Yes, the more fuel you command the injectors to inject, the higher the heat will be. They are nothing but a complex valve and if they run and idle fine, its highly unlikely the injectors are bad. The command signal to hold them open longer is not happening or perhaps not happening completely.
Toby,
I have a customer running a Bully Dog DL and the injectors work fine with it. He reports the BDDL is picky on the throttle at first, but he is now used to the change. With twin turbos and the BDDL on the middle program his EGT is less than 950 degrees at WOT.
Don~
Toby,
Don~
Boy it'll be a looooooooong time before I go to twins, but that's good to know! I'm running the BDDL in "TOW" mode all the time, and the power is good but even with the Scotty III and the 4" exhaust, I can hit 1250 degrees in cool weather pulling a decent hill. I'm thinking if these injectors will help cool things down a bit and give me some power and economy to boot, I'd be a happy camper!! Think it'll work, specifically while towing?
Toby,
I just got the low down on the BDDL and the injectors.
In the 100 HP setting ( the middle ) it is making 1050 EGT at WOT at the 3000 feet elevation level. You can subtract about 100 degrees for sea level.
So far everyone is seeing a mileage increase when they changed to the flux. 1-2 and sometimes 3. One guy had a 4 MPG increase but that was changing from a large honed injector.
I suspect you will get a mileage gain. Even towing
Don~
Don~
Originally Posted by midwestdually
so its now 06....are these injectors out for the 04.5's?
Don will have to answer your question directly about what he has or is doing with the 04.5 and up injectors. But I do remember reading a few months back that he thought the stock 04.5 injectors were very difficult to improve on. The 03 and 04's were different.
We have mileage, smoke and heat control, and about 20HP so far. This is keeping everything safe.
We have made as much as 126HP, but really anything over 20 makes too much heat and smoke. I suspect a few more months are needed.
Don~
Don~
injectors for 04.5
Facts
I have Don's Flux in my 03,and this being the 6th set of injectors I've had in the truck,I can tell you the facts!!!!! DON'S ARE THE BEST!!!!!!!!!!I'm not a friend of his,or do I know him at all,so I'm stating from my personal experience,and after spending $4000 dollars on injectors for my truck,I figure I have all the experience I need.I'm not going to start a brand war,or bad mouth other brands,but I can tell you that if you want an injector that doesn't smoke all the time and kill your fuel mileage,then DON'S ARE THE ONLY CHOICE YOU HAVE,and if anyone would like to challenge that statement,I will gladly take the challenge!!!!! And for those that have just injectors and no TST box,then this will not apply to you,but if you are one of those.If your truck smokes at WOT and isn't making over 450,then you have the wrong injectors too!!!!!!
bradler
Feb 18, 2009 12:43 PM
OldSmokey
19
Mar 26, 2008 05:11 PM
metal_miner
52
Jun 23, 2007 02:52 PM
O.T
May 30, 2007 08:55 PM
MoparRiggan
Jan 10, 2007 03:31 PM
