whats the best stack with a Quad STD or Race?
I already have the Quad std but I have to send it in for the update and Im thinking Ill just have it upgraded to the race ver. I know the Va duration box stacks well with the Quad stuff. Is there any other options out there?
That VA box is a great stack but you have to watch your temps. With my stock turbo I only saw around 1300 degrees at 30psi. With the new turbo I hit 1500 degrees at 42psi. And that's with injectors. It ran great but I didn't want to deal with the temps so I switched to my new stack. This combo gives me lower temps but it's really touchy now...
Well we were at a dyno event Sat and I got to see a lot of stacks on the new Trucks and a lot of combos with Injectors.
Our Race box on a 2005 with a 4" straight piped and our intake made 452rwhp. I don't remember the torque, but it was not completely right.
We saw a truck with a Crazy Larry stacked with our Race box and it made 547 or something.
We saw one of the Bullydogs reps truck make 399. I am not sure if it was the crazy larry or what but it had the Outlook and a dual 4" exhaust. I would think he would have had the CL in for the dyno day, but who knows?
We saw a CL and a EZ make 47x soemthing?
There were a lot of trucks with different boxes and injectors in the 460-480 range, these were 03-06 trucks.
I think the dyno was reading a little high, but not too bad. The torque numbers are a little off because that style Mustang Dyno reads engine torque at the rear wheels. This is a little different and it is measured by a strain gauge. I would say you need to reduce the torque number by 20% to be very accurate.
yeah i dynoed 547/1375 with quad andcrazzy larry . but ive only got your standard box but talked to stan about getting the race box. i rode in my budy jason and their was a big difference between the boxes.
I wished I could have met you there. I had some demos we could have slapped in there when you were on the dyno!
Good number although I think the torque is off.
Quad
i was going to talk to you but everytime you were close youd say i hear enough of this every day and plug your ears. i met you back in 02 when i had my ford with your 4 bank chip, that thing would run.il probaly come buy your shop in a month or so to get the race box, or ill have jason wilson thats a dealer of yours to get it for me.
I just get tired of hearing the dyno spool up. Unfortunately I spent a lot of time right beside the dyno on Sat.! I love dyno events, but I end up feeling like I am at work! It is not bad inside the truck, but when you are behind the truck it gets loud!
At events just grab whenever and we can go away from the stinkin dyno! I tried to spend as much time as possible in the shop, but for one reason or another I ended up back beside the trucks!
I will also say that the new Mustang softare is 1000% better than it used to be. At least they are working on their stuff.
When we get fully moved into the new building
We will haev some sort of big shindig out here!
turbotowrig
Feb 26, 2008 06:45 PM
LFD2037
Jan 25, 2008 11:59 AM
LFD2037
Jan 7, 2008 11:12 AM
goose2w1
May 23, 2007 05:55 AM
bubba001
Mar 7, 2007 08:58 PM
