At what point does pressure hurt the injectors?
Old Mar 14, 2006 | 06:19 AM
Dodgezilla's Avatar
I used to run my EZ on levels 4 and 5 when I first got my truck. Recently DonM did my injectors and found one of them to be damaged, apparently from the pressure. I just got a TST box and an EZ box again to stack together. The truck runs great w/ the EZ on level 2 but on level 3 it is much, much more driveable. What do you guys think? Is level 3 too much pressure for these injectors? It's 60hp at that setting....
Old Mar 14, 2006 | 06:35 AM
NB64's Avatar
The sad part is that out injectors are supposed to be rated for 26 thousand psi and these modules are not suppose to increase the pressures beyond the designed limit. So what gives?
Old Mar 14, 2006 | 06:40 AM
roc155's Avatar
thats what i've been trying to find out myself except for the superchips 3805. what is the pressure raise on each different setting?
Old Mar 14, 2006 | 07:06 AM
MikeyB's Avatar
I did some research on this subject before getting my EZ. Seems like level 4 (and above) will damage the injectors after a short period of time (mileage). Believed Don M mentioned seeing damage injectors with 20-30k miles of use at the higher settings.
One member on another forum went 150k miles before having to replace his injectors running at level 3.
At levels 1 and 2 no telling. I think EB290 has 280k+ miles on his with the stock injectors running at level 2.
MikeyB
Old Mar 14, 2006 | 07:24 AM
Dodgezilla's Avatar
Cool. Level 3 is sooooo much better than level 2. I don't think I can go back!!
This truck is a Rocket now!!!!!! Sweeet!!!!
Old Mar 14, 2006 | 07:27 AM
roc155's Avatar
i'm guessing that the level 3 you all are talking about would be about the same as mt tow/per (about 53 hp) level 4 would be more like my perf (100 hp ithink ). the truch sure drives better in the perf but i too am worried about damage. i have called the programer manufacture but of course they tell me oh yea it is safe for everyday use and long term reliability.
Old Mar 14, 2006 | 07:38 AM
MikeyB's Avatar
Just remember, your mileage my vary.
MikeyB
Old Mar 14, 2006 | 07:45 AM
Dodgezilla's Avatar
I know the overhead gets screwed up too.
Level 4 is supposedly 70hp but on the dyno I actually got 100hp out of my first EZ. Unfortunately it knocked my mileage down 2 points. I guess I need to check to see how I'm doing right now.......
Old Mar 14, 2006 | 07:47 AM
MikeyB's Avatar
Not sure. The Edge EZ is a pure pressure box. I don't know if the Superchips is pressure only and or duration and timing.
Seems like pushing pressure past the 60hp mark is where the damage begins.
If your looking for long life out of the injectors I wouldn't go past the 50hp mark for pressure.
BTW, the information I'm giving is for the SO/HO Cummins, not the 600/610.
The 600's runs at a higher rail pressure than the earlier engines. My guess is not go past the 40hp range on pure pressure.
MikeyB
Old Mar 14, 2006 | 06:06 PM
043500QC's Avatar
I`ve read someone`s report on the pressure boxes somewhere ( I can`t ever find an article I refer too when I need it) that studied the pressure jumps in realation to hp. What they came up with was every 1k rise in rail pressure equaled about 13 rwhp. So, going off that number, if you run the EZ on level 3 (60hp) then that should be about a 4600 psi jump. I kinda find that number hard to believe personally, but then again, you aren`t always getting 60hp out of it either. Also, they were measuring rwhp, not SAE hp, so I`m wondering if all the manufacturer`s measure the added power at the crank or at the rear wheels. Food for thought I guess.
Old Mar 14, 2006 | 06:13 PM
cquestad's Avatar
With stock injectors...I have found 50-60 hp of pressure the "sweet spot" when stacked with the TST.
Old Mar 14, 2006 | 07:15 PM
Dodgezilla's Avatar
The power seems great w/ the EZ on the 60hp level but I just don't want problems 2 years down the road because of it.....
Old Mar 14, 2006 | 08:11 PM
realsquash's Avatar
I believe the injector damage is not because of short bursts of high pressure, but sustained high pressure. I think the EZ bumps the pressure up a lot higher during cruise than you would normally see.
Andy
Old Mar 14, 2006 | 09:59 PM
Syndicate's Avatar
Wont Don Ms injectors take more pressure anyways. I was told that honed injectors seem to be much better at handling the pressure.
Old Mar 15, 2006 | 04:19 AM
Dodgezilla's Avatar
I hope so. I PM'd him but didn't get a response... Maybe he's out of town.....
