What Options Are There for More Air??
Thats MR Hoss to you buddy!
Originally posted by Kyle Graham
Yes you should see less smoke with more air. Do you guys really see a difference in performance with drilling holes in airbox because you still have a square filter which lacks filter area compared to conical filter whether or not it's cotton guaze or bhaf you gain tremendous filter area. I just always see that in people's signatures and it doesn't make sense to me so I tried it I have a couple airbox's lieing around so I swiss cheesed one removed my bd polished stainless intake and through it on and I saw higher egt's and worst turbo lag so I put on the other one I had with no hole's in it and got about the same results only difference was turbo noise. Just a little R&D I wanted to share was kind of a boring day today
So...whether it makes sense or not it is definitely an improvement over stock.
SO....I guess I have more air....and an air box that you can see through. Hopefully I won't get any water up in there. [/B][/QUOTE]
What if you bought an outerwears cover, cut it so you can wrap the bottom of the stock box and attached it somehow. This would seem to keep extra dirt and water out of the holes you cut in the bottom of the box. Just a thought.
I just changed the stock filter on mine at 15000 miles with an OEM Mopar. That gives me about 15000 miles to come up with a nice BHAF setup for my next change. I have plenty of threads to read on it.
John
John
Originally posted by Hoss
I don't know that I've gained anything as far as performance is concerned, or even EGT's for that matter (I don't have gauges).
jesussaves
Nov 15, 2009 04:56 PM
Megaramasaur
May 10, 2009 04:11 PM
