what injectors?
Old Oct 9, 2008 | 01:13 AM
smokingdiesel's Avatar
what injectors?
I have a 2004 2500 305 HO with a six speed. I have a cold air intake, gauges, six inch stacks, edge juice with attitude, and bullydog powerpup. I want more power. What injectors would be good for the mods i have done. I was thinking DDP 90-120 , or edge jammer nozzles 100. What do you think? Thanks for the help.
Old Oct 9, 2008 | 03:49 AM
Speed Shift's Avatar
Right now I would say a turbo would do you alot better than more fuel. You also need a fuel system, or you will drain the rail if you arent already.
I would sell the Edge and Bullydog, buy a Smarty and mechanical gauges(pyrometer,boost,fuel psi, rail psi). Then a turbo and fuel system, after that you will probly be smoking the clutch so you will need a stronger clutch.
These trucks are capable of making alot of power with stock injectors, but if you want to go bigger and get sticks, you will need the parts to support them first.
Old Oct 9, 2008 | 05:27 AM
dodgeboy59td's Avatar
Unless your planning Cp3 mods i would put anything over a stage 1 injector in. Personally i would go with a F1 Flux injector, and then 2 choice would be the DDPs.
But a charger would be more useful to you than injectors at this time. something like a 62/14 would net you a good running truck.
Wes
Old Oct 9, 2008 | 09:41 AM
Hintz's Avatar
x2, you are already getting out of MAP range w/ your stock turbo
Old Oct 10, 2008 | 12:46 AM
thanks guys i've heard so much about injectors and turbos and i didnt really know what would be best .
Thanks
Old Oct 10, 2008 | 11:15 AM
DUKCALN's Avatar
Turbo first, lift pump second and then you can support those DDP 90's.
Old Oct 10, 2008 | 09:29 PM
gus's 03's Avatar
turbo, lift pump, gauges, smarty, clutch, cp3, injectors
do you have a hp goal? be realistic with it and work wit it in mind. this way your not taking baby steps and buying/selling over and over.
your sig isnt filled out so we dont know what your running for a trans, but just assume that with a smarty, to take full advantage of " normal " programing you'll need upgrades.
also, what do you do with the truck? dayly drive? race? sled pull? tow?
a awesome all around setup would be a 62/12/71 and a set of small injectors. ( ddp50's or flux 1.x) you shuldnt have any trouble making 500hp on that.
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
