What injectors?
Old Nov 25, 2006 | 04:48 PM
djgaston's Avatar
I hope Don replies to my PM. I will try to call him Monday morning if he doesn't reply. I need to get on the ball with this. Thanks for the info guys.
Old Nov 25, 2006 | 05:03 PM
masonic-dodge's Avatar
A 62/80 has the flow of more like a 15.5cm not a 14. I called II and HTT and asked about it. The wheel size is the real difference between the two.
CRIS
Old Nov 27, 2006 | 06:15 PM
djgaston's Avatar
Went with F1 stage 2's, Source Automotive had some in stock and they'll be here in two days.
Old Nov 27, 2006 | 06:22 PM
Luken's Avatar
Good choice!
Rip always has the goods in stock! I've had good luck doing business with him.
Lucas
Old Nov 28, 2006 | 08:40 PM
lowboy18011's Avatar
Ha ha, posted a question about F1 injectors a little while ago and have gotten no response. Found this thread doing a search. Are you going to run the stage 2's on you're stock turbo for awhile. I must be second class because I called Source Automotive on Monday and was told that I would have to send my injectors in to be upgraded, ***! On another note, have you and Don installed the long arms on you're truck yet? His website says that something is in the works and I'm wondering if you're truck is the guinea pig.
Old Nov 29, 2006 | 01:25 AM
djgaston's Avatar
I think they probably hold on to a set or two of injectors for emergency situations, and I'm glad they do. I can't send in my injectors first. But if I wanted the Stage 1's, that is what I would have had to do. I just said to give me whatever they had. Yeah, I'm going to run the Stage 2's with my stock turbo for now. I might buy another turbo when I get the core charge back, I don't know. I really need new brakes more than an upgraded turbo.
Since my truck is down and about 5 hours away from me, the radius arms aren't installed yet. But yes, my truck is the test rat. I've got some measurements and stuff and Don already has the arms laid out, we're just getting the final measurements and then he'll send me a set to put on and test out. Don is a good man; the radius arms are going to be awesome!
Old Nov 29, 2006 | 05:54 PM
Right on, once you guys get the arms worked out, my truck is next in line.
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
