What drop is everyone using for their trailer hitches?
Old Mar 28, 2006 | 12:25 PM
WACTD's Avatar
As measured from the ground to the top of the receiver's ball mounting surface.
My boat trailer is level when the top of the receiver is 18 inches off the ground. But trailers vary a lot, and I'd like the option to tow different trailers without too much hassle. Let's hear what everyone else is using for receiver drop distances.
Thanks!
Old Mar 28, 2006 | 12:33 PM
midwestdually's Avatar
a 6 or 8" and you should be fine unless running a lift
Old Mar 28, 2006 | 12:43 PM
P.J's Avatar
P.J
6 when hauled my tractor (heavy) 8" for my boat cause it's light and I like to keep the prop from dragging on the pavement (not that I have done that or anything)
Ski Boat, can't do much about the prop and rudder under there..........
Old Mar 28, 2006 | 12:44 PM
cummins_cowboy's Avatar
I only use a 4" but it is a little high for our bumper pull trailers. Although it is the perfect height to find it with your knee
Old Mar 28, 2006 | 01:02 PM
SolarYellow05's Avatar
I use a 6" solid forged hitch with a 1.25" shank ball for hauling heavy, and I have a light duty 8" drop for lighter loads. Works great with 35" tires.
Old Mar 28, 2006 | 01:24 PM
WACTD's Avatar
I've got a stock 3500, but my measurements show that I need a 4.5 inch drop to make my boat trailer level (underside of trailer coupler is 18 inches). This would also match the height of my wife's minivan and the Pathfinder I recently sold.
This is with my bed entirely unloaded. When you say 6-8 inches with no lift, that's a LOT lower than what I seem to need. What height is the underside of your trailer's coupler?
Old Mar 28, 2006 | 01:25 PM
IA_James's Avatar
I've got a 5 1/4" with the 1" shank. By the time you throw a little firewood in the box it's juuuussst right.
Old Mar 28, 2006 | 01:31 PM
wap's Avatar
wap
4" for me, I dont want it to drag off road and if I need to put a ton or two in the bed its still high enough.
Old Mar 28, 2006 | 02:12 PM
BigBlue's Avatar
I'm running a 4.5" drop I believe it is (maybe a 5") and I've got a 4.5" lift with 35" tires and the little utility trailer I pull sits just about level. Maybe an inch to high but nothing big.
Old Mar 28, 2006 | 09:43 PM
siotwo's Avatar
2" drop when I hauled a PT Cruiser on top of a Uhaul car trailer.....2-4" on my utility trailer or boat.
I just picked up a Rapid hitch to make things Juussstt Right.
Old Mar 29, 2006 | 08:11 AM
telephonman's Avatar
I use a B/W tow and stow hitch, you can adjust the drop distance. Also is has three ball sizes on it, very nice all around hitch.
Old Mar 29, 2006 | 08:25 AM
bnold's Avatar
I run a 6.5" while pulling my Mastercraft X-30, rides just about right. It has an inboard so there is a lot to screw up under there if the boats not level... Prop, Rudder, Driveshaft... The 'cage' that surrounds everything back there is about 4-5" off the ground when the trailer is level.
Old Mar 29, 2006 | 10:03 AM
rjordan's Avatar
4" for me just right on most stuff
Old Mar 29, 2006 | 06:36 PM
rjm022's Avatar
i use one of these. never a problem hooking up or pulling anything!!
http://www.awdirect.com/awdirect/cat...tion&linkid=57
Old Mar 29, 2006 | 06:41 PM
WACTD's Avatar
Interesting that the clevis maxes out at 7500 pounds, while the ball maxes out at 10K. I would have expected the clevis to have the higher rating.
